'mini Blade'
#61
Posted 13 January 2010 - 11:02 AM
#62
Posted 13 January 2010 - 11:26 AM
i will have to look into the size of them an see if they will fit in the 13's. cant imagine there too big ! cheers for the suggestion
Timmio85: cheers mate, i will have a look into it, too be honest VFM is what im after at the mo with a limited budget, dont want somethin that will brake the bank, but want somethin that will brake the mini.
Edited by Sean12, 13 January 2010 - 11:27 AM.
#63
Posted 13 January 2010 - 11:31 AM
#64
Posted 15 January 2010 - 10:51 AM
#65
Posted 15 January 2010 - 12:18 PM
cheers guys
#66
Posted 15 January 2010 - 06:37 PM
I was thinking about a bike brake dics and cal for the rear
#67
Posted 15 January 2010 - 08:22 PM
yeah i have been thinking about this too for some time, just been tryin to think of a way to mount the brakes inboard and some how attach the callipers to the aluminium bearing carriers. It would be my preferred option as i think it would look sweet ! and should more than cope with the braking forces usually needed in the rear. what bike brakes have you been thinkin about ? busa's maybe ?
#68
Posted 16 January 2010 - 05:42 PM
#69
Posted 17 January 2010 - 01:50 AM
#70
Posted 17 January 2010 - 07:29 AM
Aparently there are some callipers from a lancia/fiat that have cable handbrake on that would be ideal, so going to look into that more.
...the front space frame will have an inboard suspension set up to, less unsprung mass and all that...
rear toyota levin callipers have both hydraulic and cable connections. i've got them in my 340i and they work fine. i assume corollas with disk brake rears run the same ones?
by the way, inboard suspension adds to unsprung mass, not the other way round. its benefits are packaging and aerodynamics. waste of time on a spaceframed mini imo, unless you want to put in adjustable bellcranks so that you can adjust the effective spring and damping rates without touching the shocks/springs.
#71
Posted 28 January 2010 - 01:49 PM
Oh yea sorry of course it will, must have been a long day they day I wrote that. I see your point about having the suspension inboard and it's beneifits, not really up on suspension at the mo need to do lots of Reading to come up with a design.
Made an new purchase the other day, another mini off a mate at uni picking it up next weekend so will get pictures up soon of it an will crack on with cutting out the back end.
Spoke to zcars yesterday and got a quote for pair of trailing arms. I got quoted £500, I nearly fell over, that is just ridiculous, so looks like I'll be fabricating them myself.
Sean
Edited by Sean12, 28 January 2010 - 11:00 PM.
#72
Posted 28 January 2010 - 07:12 PM
340i- cheers mate I'll have to have a look into the Toyota levin brakes cheers for the suggestion.
Spoke to zcars yesterday and got a quote for pair of swing arms. I got quoted £500, I nearly fell over, that is just ridiculous, so looks like I'll be fabricating them myself.
Sean
Hay dude, Have a look at some e30 rear trailing arms for the rear end. They're quite a good design of could be adapted quite easily. Ive been thinking of using the for a bike conversion.
#73
Posted 28 January 2010 - 10:06 PM
#74
Posted 02 February 2010 - 11:10 PM
It also allows a rising spring rate if you design the geometry correctly - which is really the most important advantage. Its very difficult to acheive rising rate without the bellcrank.
Edited by SukiDawg, 02 February 2010 - 11:10 PM.
#75
Posted 03 February 2010 - 05:50 PM
c.robertson, they look sweet, they could be perfect, and far cheaper than zcars ridiculous £500. cheers for suggestion mate will deffo have to look more into this, i may try an fabricate my own, but this could be a good time saving option. might have a look around on ebay !! cheers mate !
Hello Sean,
I have a set of semi trailing rear arms from a 4*4 sierra, they are in excellent condition, blasted and powder coated, picked up a few marks on the black powdercoat but otherwise as good as secondhand as you could get without buying new ones, fitted with new bushes. £40 plus postage or pickup from Chandlers Ford near Southampton
I will post a picture to show how good these are, probably Thursday
David
