Right then!!
Got my sump guard the other dayand am looking to fit it tomorrow. It didnt come with any bolts or screws or anything or instructions and am just trying to find out if i need any bits to fit with it or it sit on using existing bolts/screws. So advice needed please
Sump guard fitting
johnnysti
, Oct 08 2005 06:51 PM
3 replies to this topic
Posted 08 October 2005 - 06:51 PM
Posted 08 October 2005 - 07:21 PM
it should just bolt to the subframe :grin:
allthough mine hit the bottom of the gear box first :sad: so i used the cotton real type exhaust monts as a bot/spacer :smartass:
Posted 09 October 2005 - 06:49 AM
Is there already bolts in the subframe to use or do i need to get some? If so does anyone know which type to get??
Johnny
Johnny
Posted 09 October 2005 - 12:35 PM
i had the luxary of a 2 post lift when i fitted mine. mine's one of those cheap ally ones you pick up at shows for £20 which you can't really see as the number plate is in the way.
still: i had to drill all the holes myself, after bending it in a vice because the bolt holes would have been to near to the vertical bits of the subframe.. and had no room to poke through..
