took carb needle out today, its got a wear a tear ridge on it that shouldn't be there.
Will it make any difference to the running of my hif 44, 1991 cooper(standard).
Or should i replace the needle asap?
If so, anyone give me a link to the exact needle need?
Thanks all in advance.
needle help
charlie
, Oct 09 2005 10:18 PM
3 replies to this topic
Posted 09 October 2005 - 10:18 PM
Posted 09 October 2005 - 10:40 PM
Well if it was running Ok you might as well keep it until you rolling road it. If you just change it for another one, it may give you a worse set up than to begin with.
You could also reprofile a needle. Its a dark art but you can get it spot on with the aid of a Lambada sensor.
Posted 09 October 2005 - 11:05 PM
i was just hoping to replace to see if there's any improvement.
Any links anyone?
cheers
Any links anyone?
cheers
Posted 10 October 2005 - 07:05 AM
HS & HIF needles are designed to wear, and it's also unlikely that a ridge (unless it is along the length of the needle ) will form naturally...
It will not hamper the performance of your carb, but may make you mixture a little richer than std..
Your options are, buy a replacement needle ( same code ) from Burlen, and replace it, you car will still need tuning.. but it's also very likely that you will also need a new jet which will require a carb service kit, also available from Burlen.
Clicky link
Clicky link
