Can't seem to get the stage 1 kit to fit.
The problem is that I can't fit the air filter (pancake K&N). There's not enough room between the engine and the bulkhead. If fitted the inlet manifold and the carb but the filter just wont fit. I've tried fitting the parts in different variation but the problem is that there is not enough space. It won't even fit without the carb spacer! What can be the problem?
It's a 998cc with a HS4 carb.
Please help because the mini is off the road :nugget:
Thanks in advance, Jam2005 :grin:
Trouble fitting a stage 1 kit
jam2005
, Oct 10 2005 07:21 PM
5 replies to this topic
Posted 10 October 2005 - 07:21 PM
Posted 10 October 2005 - 10:35 PM
Please please help!
Posted 10 October 2005 - 10:50 PM
wrong filter?
Posted 10 October 2005 - 11:29 PM
You need to tilt the engine forward slightly to gain enough room to get it in.
It may also be necessary to modify the bulkhead very slightly (using a big hammer).
Posted 10 October 2005 - 11:43 PM
it is suprising how important a hammer is when working on your mini. :fear:
Posted 11 October 2005 - 08:56 AM
They will fit... but the best filter to use is the cone shaped one... but as philster says, you may have to release the top engine steady to allow you room to get the filter on..
And the big hammer is another very useful tool
