Twin Engined, 4wd?
#16
Posted 08 November 2009 - 09:31 PM
#17
Posted 08 November 2009 - 09:36 PM
#18
Posted 09 November 2009 - 09:28 AM
No because you could make the one for the rear however, and then make the front exhaust smaller diameter for example to restrict the back pressure making them run in sync if you get me?
yeah, I understand, right, I need another Mini. Anyone fancy a trip to Margate to help build this, lol, theres as much Stella and Dorito's as you can dare cram in your face's
#19
Posted 09 November 2009 - 10:53 AM
#20
Posted 09 November 2009 - 01:53 PM
#21
Posted 09 November 2009 - 01:58 PM
David
#22
Posted 09 November 2009 - 02:02 PM
If you just knock one engine into neutral and switch it off, then drive with the other, surely you will destroy the gearbox? Itll still spin one shaft and a few gears at very high RPM with no oil feed?
see i thought the gears in the gearbox sat in oil, so the only thing spinning would be in oil naturally circulated around the box due to the spinning motion.
i dont know much about bike engines but i cant see it being a problem.
#23
Posted 09 November 2009 - 02:54 PM
*edit*
Here you can see where the gearbox is in relation to the oil site glass
Edited by alexcrosse, 09 November 2009 - 02:55 PM.
#24
Posted 09 November 2009 - 02:57 PM
Regarding the gears, they sit in oil in a mini gearbox because it has the gearbox and sump combined into one but most bike engines have the gearbox higher up than the sump so they would not be sat in oil, whether that means there would be a problem when running in neutral i dont know...
#25
Posted 09 November 2009 - 03:15 PM
#26
Posted 09 November 2009 - 04:38 PM
Just my worthless opinion, but you will go faster round a circuit with a single high power engine in a lightweight well sorted mid engined mini
David
I must agree. Same power, less weight/better distribution.
#27
Posted 11 November 2009 - 12:47 PM
#28
Posted 11 November 2009 - 12:48 PM
David
Very true
#29
Posted 11 November 2009 - 12:51 PM
The idea of using an engine to power each set ofwheels would surly mean doing away with any trick boxes. Using 1 engine/gearbox to drive the front and one to drive the rear! Therefore creating RWD-4WD-FWD all on the move.
Thats the part i like the idea of, then surly to disengage 1 of the engines you just knock it into neutral?
that does sound sweet, the trick would be to get each to change gear at the same point but still allowing one engine if you wanted to be left alone.
easier with the sequential bike engines as you could link both sticks as one and unbuckle them to drive on the road.
having different final drives might cause other problems. getting top power out of one engine will cause the other to overrev? equally down shifting could over rev one. how about just down tuning or restricting one engine so that its power curve matched the other engine but just less power. that way it would have predictable smoother power ?
That sounds like the way to go Reidy, As I said a 'T' shaped shifter split down the middle 1 side of the T on 1 gearbox and the other side of the T on the other, ok guys we need an engineer of some kind to make this work, i think i know just the man. Would you suggest using Z cars front/rear subframes and kits and bolting to an existing shell, or going for a space frame?
#30
Posted 18 November 2009 - 09:11 PM
