Hi,
I've been lurking around here for a while and have done lots of reading in the archives, great forum thumbs up!!!!
My project is turning a 89 998cc mini city into 1.4 honda civic(89) powered mini, for a daily run around for the wife.
I have some wide arches which i will need 6 inch wheels to fill them. My main concerns are she will dislike the heavy steering at slow speeds. I can either fit smaller arches and smaller wheels or fit power steering! Guess what the engine i'm fitting has a power steering pump attached and the doner car has a power steering rack. So, has any one fitted a power steering rack from a 89 honda civic. Main issue i can for see are mounts, uj to mini upper steering columb and track length and rod ends. Mounts i could probably fabricate from the honda ones and the track can be shortened by chopping the length down. Would it be best to try and get a die and re-cut a thread on the end for the mini track rod ends or get the end of the mini rack welded on?
Also i have removed the wiring loom for inspection and cleaning, does any one have a drawing of the the loom and all the connections so i can check with mine and repair it if required, i can't get on with the haynes manual ones there pretty pants!! something with wire lengths and colours written on would be ideal.
Karl
1st day with my new project
kada1980
, Oct 12 2005 09:56 PM
1 reply to this topic
Posted 12 October 2005 - 09:56 PM
Posted 12 October 2005 - 10:13 PM
http://www.16vminicl...orums/index.php
here might be ale to help on the honda engine front.
It might be easier o fit a K-series rover engine if you asre just after a useale no a series mini.
Cant be of much more help but good luck.
