Bouncy Handling
Posted 15 November 2009 - 05:34 PM
It seems very bouncy on the front end and not much grip through the twisty bits ( i would be quicker in an original mini through the corners).
I have tried dropping the air pressure in the tyres to 22 front and back which are yokos and checked the clicks on the shocks and they are half way, i have also had the car set up at z cars!
Any suggestions?
Posted 15 November 2009 - 05:40 PM
Try less damping on the front.I have a z cars road kit mini with a gsxr1000 with their new front end and lower mounted engine and i have had it on the road about 3-4 weeks but to be honest im not very happy with how it handles.
Any suggestions?
What weigh is your car ? what rear springs do you have ?
Allan
Posted 15 November 2009 - 06:35 PM
Posted 15 November 2009 - 07:28 PM
What rate are the springs ?620kg and they are the coil overs that z cars supply protech i think!
It is printed on the spring.
Allan
Posted 24 November 2009 - 04:51 PM
Posted 24 November 2009 - 10:00 PM
Its printed on the area that seats against the shocker top or bottom.tried to see earlier but its either not printed on them or im being blind!
You need to jack the car up a bit and let the suspension droop.
Allan
Posted 24 December 2009 - 08:54 AM
Posted 25 December 2009 - 12:06 AM
bouncy ride just doesnt seem right somehow
on a bike engined car you can go lower on the tyre pressures around 18 psi cold all round
when you say bouncy in what way ?
is it the front of the car or the rear thats causing concern
did you look at the springs and read the poundage
how much preload is there on the springs at each end
how many clicks of adjustment have you on it from zero
im sure theres got to be an explanation for it as all the others are ok we just need to identify what it is
you may have a duff shocker or something although that would be very rare as we have sold thousands of the protech shocks with not problems
call me direct for a chat on 07786 707734
Posted 25 December 2009 - 12:09 AM
bouncy on the front sounds like maybe wrong spring rate fitted which can happen just get me a reading of the spring rate
alternatively you could have too many clicks of damping on there and drop tyre pressures a bit to 18 psi cold
chris
Posted 08 March 2010 - 01:52 PM
just re read your post again
chris
Lol, was just reading through some of these posts on a research mission and came across this. Chris, answering Mini questions on Christmas day is beyond the call of duty!
Posted 10 March 2010 - 11:14 PM
christmas day 2008 power harrowing the motocross track
christmas day 2009 building a grass track car for daughter and son in law
hyper active as a child cant sit still
love building cars and just doing things, besides it gets your appetite up for dinner
chris
Posted 11 March 2010 - 07:43 AM
What should the poundage of the springs be front and back for a bike car and a Vtec?
Many thanks
Posted 15 January 2015 - 04:52 PM
Can someone advice what sort of springs are used in hayabusa and vtec conversions? I´m having the feeling my front springs are way to stiff.
Posted 16 January 2015 - 05:15 AM
Could it be that the car insn't alligned right? This could cause a bouncy front to....
Mine isn't alligned yet and I have a bouncy front at the moment.
Good luck
René
Posted 22 January 2015 - 03:08 PM
Geometry set up was done twice. Not been on the scales but I would really like to know what spring rates are other Z-cars using. Mine are currently 200lbs on the front and 400 lbs on the rear.
Anyone knows there spring rates or has experienced with different ones?
