New fantastic dizzy!
Posted 15 October 2005 - 05:24 AM
Just finished installing a new 123 dizzy found here- http://www.123ignition.nl/ FANTASTIC!!! Runs like a new car! Accelerates smooth more power and more gas mileage! no vac advance, but the distributer comes with an onboard computer that you can set the advance curve with, no need for the vac!!!
Stumbled across this one by accident, Dizzy had gone south, so decided to replace it . thought my engine was out of a metro- A+, got the dizzy for the A+ and aparently I have an old a series, not metro.... Called up 7enterprises- they sent me this new distributor WOW!
Got it for about 325$ which would be about 160#'s
By the way, Which is better, the A series or A+... Just curious if I should be angry at the guy who sold me the socalled Metro A+ or thank him..
Posted 15 October 2005 - 07:38 AM
Personally, I'd be thanking him, because the older cranks, rods etc are considered to be better, and there is a suspision that the block are made of better quality iron.
I use A series blocks in preference to A+, but they are getting harder to find...
**edit** intereseted in the dizzy's though, will have to have a read up on them, as I'm considering going to mappable ignition curve.
Edited by GuessWorks, 15 October 2005 - 07:39 AM.
Posted 15 October 2005 - 07:47 AM
Posted 15 October 2005 - 10:33 AM
Posted 15 October 2005 - 01:04 PM
see: http://tdcperformance.ca/
For those of you in the U.K.... I thought these were actually being built in Europe... perhaps The Netherlands?
I thought there was provisions for a vacuum hookup? I seem to remember that there is no actual advance unit on the dizzy. From what I remember, the dizzy can monitor the vacuum electronically and uses that information to add advance to the curve when necessary.
By the way 77 Leyland, if the previous owner had sold you an A+ I don't think there's a 123 dizzy for that block, at least not yet.
Posted 15 October 2005 - 01:43 PM
Posted 15 October 2005 - 08:38 PM
I'm really curious because I was thinking of picking up an electronic ignition kit for the pimp mobile but this this sounds like the bomb!
Posted 16 October 2005 - 12:09 AM
Nice product!!!!!
Posted 16 October 2005 - 12:16 AM
I was told that just rotating the Dizzy cap on its bracket can make it runn differently? is this true?
Posted 16 October 2005 - 12:40 AM
Sounds very much like the ignition on Injection Minis, but without the injection, all built into a neat package that is the distributer. All electronic with built in crank possition and a mechanical distibution of spark. Very cleverI thought there was provisions for a vacuum hookup? I seem to remember that there is no actual advance unit on the dizzy. From what I remember, the dizzy can monitor the vacuum electronically and uses that information to add advance to the curve when necessary.
Posted 16 October 2005 - 04:56 AM
Running over 300 miles with it now and the mini is running the best it EVER has!! Heres a cheesey video, but the car sounds bad A$$!!! You will need the DivX Codec to view- PS: Its real hard to drive, shift, and film all at the same time, so this is obviously not all she's got! And the speedo is 2/3 accurate, so not bad.. http://www.coinspire.../movie_0002.avi
And no the speed limit on that road WAS NOT 25mph......... what?!?! I have no idea what you are talking about
