Hi yer, I've just bought a new mini equinox. However when it came to driving in the dark i noticed a few things with my head lights. When the dipped lights are on the angel eyes turn on and then the main lights turn on 3 seconds later. when main beam is on all is normal. When full beam is on the drivers side light turns off. Is this just an electrical problem or is it the actual lights?
Roo
xXx
Head lights
Roo
, Oct 15 2005 10:35 PM
6 replies to this topic
Posted 15 October 2005 - 10:35 PM
Posted 16 October 2005 - 12:03 AM
Is it the newer modle with the 24 fuse fusebox. If it is then there is a fuse for each headlight. Might be that the fuse for the drivers headlight is buggered.
Sounds like wiring to me though. Could be the switch gear, Could be the conections. Could even be knackered bulbs.
Do you have another set of Head lights to test it with?
<|Ben|>
<|Ben|>
Posted 16 October 2005 - 05:58 PM
equinox is a late spi. it still have the 4 fuses on the bulk head and thats about it.
it sounds like a short somewhere. take the angle eyes out and check the wiring behind the light as the side light loom has to be split to power the 2 bulbs this maybe a bit dodgy. then trace the wiring and look for splits or other faults if thats ok.
Karl.
Karl.
Posted 16 October 2005 - 09:13 PM
i do have the original headlights. Although I'm thinking about getting some halogen lights. I was driving down an unlit due carrage way this evening and couldn't see the road very well and was all over the place. Didn't help when being blinded by cars behind me.
Posted 17 October 2005 - 10:22 AM
to save me writing this all out again, read this - http://www.minifinit...ewtopic&t=28811
if you need any more info feel free to post on here, (im going to be around here a bit more now adays)
Posted 17 October 2005 - 10:51 AM
MF turning like MR is it? :fear:
Posted 17 October 2005 - 11:13 AM
nah MF still seesm to be cool, but i have many hours on the again and MF will only occupy me for so long untill im refreshing the site every min to find new posts to reply to, so im gonna put my knowledge to good back on here again, (aint been on for a while,)
Karlos
Karlos
