minispares 1380
andywaller
, Oct 16 2005 01:35 PM
12 replies to this topic
Posted 16 October 2005 - 01:35 PM
has anyone seen the 1380 that minispares sell. is this worth the money? it seems a good idea to me as i cant afford a fully built engine :sad: , but this means i only have to do the bolt on stuff!
Posted 16 October 2005 - 01:41 PM
Got a link or anything? :erm:
Posted 16 October 2005 - 01:52 PM
erm no i dont now how to do a link.
Posted 16 October 2005 - 01:56 PM
Open the webpage with the info for the 1380 on it (if there is one ) and highlight the whole address in the address bar, then copy it (press ctrl+C when it's highlighted)
then when your in TMF and writing a post click the [http://] button and a small box will appear. Paste the address into the space using ctrl+v, click ok then type what you want the link to appear as, '1380 engine' for example
simple as! :grin: :smartass:
Posted 16 October 2005 - 02:07 PM
sweet it works cheers pooky
Posted 17 October 2005 - 10:25 AM
shoddy with 'make believe' power figures. For value for money get an MED or Morspeed engine.
Posted 17 October 2005 - 10:39 AM
as above.shoddy with 'make believe' power figures. For value for money get an MED or Morspeed engine.
always get your engines from a place where you can see them being built and if possible see some evidence of the workmanship.
By the way Morspeed are VERY good (and will also supply an engine kit if needed)
Posted 17 October 2005 - 10:48 AM
As above, and the one you are looking at I would say is equivalent to Morspeeds 1380 sports engine... priced @ 560 + exchange.
and of course you will have to build it yourself..
Posted 17 October 2005 - 04:43 PM
Paul Inch Engineering in Plymouth, got mine from there for £450 and squeezed planty of power out of it.
Posted 17 October 2005 - 04:59 PM
ah ok cheers for that. i just thought i was a good idea because i am not rally confident enough to build my own engine. looks like i will just have to save for longer :sad:
Posted 17 October 2005 - 10:24 PM
or do what i did last summer... and just go for it, thaking everything off the old one methodically, making notes of anything u think u will need to rememeber(as u will forget things) then attemt the rebuild... if your unsure of anythign then just ask us or what i did what phoned simon at morspeed, as well as ready his very clear instructions! Either that or save for a bit longer ) good luck
