After finally getting my mini working, I was running the engine with the bonnet open and I noticed somthing. There is a little red thing that looks almost like a spark plug to the left of the engine, i have no idea what it does, but I could see that oil was bubbling up around the brass collar piece of it.
so, my questions are.. what is it? How much is a new one?, and how quickly should I change it?, hehe.
Ill have another look tommorow as I cant remmember exactly where it was,
thanks a lot,
pEaCE
DOm
Red thing that looks like spark plug??
Telejmp
, Mar 28 2004 02:08 AM
9 replies to this topic
Posted 28 March 2004 - 02:08 AM
Posted 28 March 2004 - 07:30 AM
Photo please
Siggy
Siggy
Posted 28 March 2004 - 07:58 AM
Sounds like the oil pressure sender? Mine leaks a bit from there too. Dunno how much to replace
Posted 28 March 2004 - 04:11 PM
That sounds like it, It will have a single wire attached and be next to the dissy.
About £5
Siggy
About £5
Siggy
Posted 28 March 2004 - 04:45 PM
you shud b able to get 1 from ur local halfors, usually a 24mm socket or spanner to fit
Posted 28 March 2004 - 04:49 PM
Try tightening it up a bit, not too much tho incase you damage the threads, you just want to nip it up.
Posted 28 March 2004 - 04:54 PM
the advantages of having cast iron blocks, threads r nice and strong in um
Posted 28 March 2004 - 07:54 PM
yep, but the sender aint cast iron.....! you can strip the thread on that just as easily trust me
Posted 28 March 2004 - 09:35 PM
For £5 change it its not worth the risk of, snapping the sender off in the block or it bursting at high speed and losing all the engine oil.
Siggy
Siggy
Posted 29 March 2004 - 07:30 AM
I had the pipe come off my oil preasure gauge sender once, oil went everywere, all over the front of my car, windscreen, roof and road. what a mess and all because of that tiny little pipe.
