Can someone tell me how i could change a cylinder head on a standard 1.3i engine for a better cylinder head!
is it as easy as it is to do a carb cylinder head!
your help is gratefully appreciated :grin:
1.3i 'S
shaun of the Tamar Valley
, Mar 29 2004 08:06 AM
1 reply to this topic
Posted 29 March 2004 - 08:06 AM
Posted 31 March 2004 - 08:01 PM
Swapping the head is easy, you may find it awkward because of the injection gubbins, but the principal is the same as a carb head.
As far as running an injection on a modded head, then you may have probs because the engine management will be set up for a standard engine, and if you start putting more or a better fuel/air mixture in, then it may confuse it. But at the same time it might not - I've never tried it. Try calling MED or somewere like that and ask them.
