Blooming...
GottaDesigner
, Oct 24 2005 10:37 AM
16 replies to this topic
Posted 24 October 2005 - 10:37 AM
Anyone know a good way to deal with blooming/hazing on black paintwork please?
The paintwork is new - I.E Resprayed within the last 3 - 4 mths - and thus on completely rust-free panels. Areas in question are the bottom corners of the doors and a touch on the panel just before the door (where the hinges connect, not sure of the tech term, sorry! :erm: )
Muchos gracias, amigos.
Posted 24 October 2005 - 11:04 AM
i dont know much about this but know a little
paint blooms when it is sprayed in damp conditions
the only way to stop this is to eather spray on a dry day/warm dry spray booth or you can use a aunty blooming thiners
Posted 24 October 2005 - 11:07 AM
So I'd heard...*Sigh* Thx, Bungle.
Trick is the damage is done, it's already hazy in those areas...is there any way to get rid of it or lessen its appearance?
Posted 24 October 2005 - 11:08 AM
you need to ask woody or bristolminimad they are the paint men on the site :cheese:
Posted 30 October 2005 - 10:40 PM
cut back with a very fine wet n dry 1200 grit or finer, then buff up using farcella compound and a polishing mop, but be carefull not to burn paint or cut through !
Camp Freddy.
Camp Freddy.
Posted 31 October 2005 - 12:57 AM
Braso.... works every time, but a bit of a s**t when you have to do the whole car
Posted 01 November 2005 - 04:24 PM
Many thankings for the f/b, guys. Sadly, I don't trust myself with sandpaper or anything remotely similar...knowing my luck I'd bugger the paint up bigtime and I can't afford re-paints on the offending areas as a result.
GW:
1) Is that 'Braso' as in Brasso metal polish?
2) You're not 'having a laugh' are you? *Winks* because I've never heard of that before.
GW:
Posted 01 November 2005 - 08:30 PM
Nope, not having a laugh, it's a very fine abrasive which will just remove that surface bloom... try it on a small patch and be amazed...
My dad told me about that one, he said that's what they use to do on the rootes/commer production line
Now there's a thing, who's old enough to remember Rootes...
Posted 01 November 2005 - 09:09 PM
*Will experiment at weekend*
Thx! ^.^
Thx! ^.^
Posted 01 November 2005 - 09:28 PM
What about the Brasso?! :tongue:*Will experiment at weekend*
Thx! ^.^
Posted 01 November 2005 - 10:26 PM
[QUOTE] *Will experiment at weekend*
test a small area first you might get an ellergic reaction !! :grin:
Brasso is pretty much the same as T-cut / colour cut, both fine abrasive liquids.
both tend to leave a smear which can be removed by polishing (recommend Autoglym)
Posted 03 November 2005 - 01:53 PM
@ Jammy.
Weather permitting, I'll see what sort of result an introduction to Brasso yields, testing on small, inconspicuous area first, and let you all know. Thanks for the tips, 'tis much appreciated!
(... And when I catch the seagull that left a message on Monty's bonnet yesterday it won't like what happens to it...Monty's a sensitive little thing, he doesn't like 'gull C**p all over him...:fear: *Becomes Gull destroying Ninja*)
Posted 03 November 2005 - 03:18 PM
wrap a fire lighter in bread and feed it to the gull............
Posted 17 November 2005 - 10:02 PM
dunno if you have done the job yet but you should use G3 paste with water for repairing this ..
hope this helps
eddie payne
hope this helps
eddie payne
Posted 17 November 2005 - 10:36 PM
If you do use "brasso" to cut back the paint finish on your mini make sure you remove it all as it contains too much amonia and will damage paint .
If left on the surface of the paint for a few hours it will leave streaks that cannot be removed as the pigment will be bleached .
best to use farecala G3 by hand (not buffing machine)
remember to wax the surface after as a freshly cut paint finish will tarnish quicker .
