How To Jack Up A Mini
19 replies to this topic
#16 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 31 January 2010 - 11:16 PM
Hi all
I have just brought a 1998 rover mini cooper 1.3 SPI
On a side note, SPI minis were made from 1992 -1996. All 1998 minis are MPI. The easy way to tell is MPI's have front mounted radiators, and SPI's all have side mounted radiators (unless air con is involved, but we'll cross that bridge if we come to it).
could be late registered!? if your radiator is side mounted its SPI, if its at the front then its MPI!
i think im right in saying some very early mpi's in some cases had side mounted rads...
Edited by rick.spi, 31 January 2010 - 11:16 PM.
#17 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 01 February 2010 - 12:25 AM
Hi all
is that like the first few hundred? my mate has a S reg, so 98 mpi sportspack, and his rad is front mounted?
#18 njathind
njathind
  • 447 posts
  • Local Club: Chichester Mini Club
Posted 01 February 2010 - 07:54 PM
Hi all
My radiator is definatly front mounted and its registered on a 1998 plate so it must be a MPI, Many thanks for the usefull info
#19 beentheunseen
beentheunseen
  • 198 posts
  • Local Club: Notts about Minis
Posted 01 February 2010 - 08:01 PM
i just jack it on the sump then get axelstands on the front subby, some people say not to do this way but works a treat for me (even tho i have to jack it up on the subby, let it down and get the jack under the sump really quickly before it settles lol...)
Lol, that's the worst advice I've ever read on this forum... Imagine the entire weight of the chassis hanging from those tiny rubber mounts! They're designed to work in compression, not tension.
Jack up and support pretty much any substantial part of the subframe and you'll be fine.
Edited by beentheunseen, 01 February 2010 - 08:31 PM.
#20 mickyh
mickyh
  • 391 posts
  • Local Club: not yet
Posted 01 February 2010 - 08:17 PM
jack it from the sump witha piece of wood between them and then put axle stands on the strongest part of the subframe thats how i do it.
