came across this on another forum:
linky linky
basically what is said is that roller rockers promote excess wear on cam lobes, and that a company called AC Dodd agrees.
what do you lot reckon? true or false?
do roller rockers promote wear?
neil_g
, Mar 30 2004 09:59 AM
10 replies to this topic
Posted 30 March 2004 - 09:59 AM
Posted 30 March 2004 - 04:05 PM
Adrian Dodd is aperson not a company is a very well respected Mini tuner, in the same league as Keith Calver. And as I have no proff otherwise I would agree with what he says.
Siggy
Siggy
Posted 30 March 2004 - 05:27 PM
Roller 'tip' rockers, and 'full' roller rockers are designed to reduce wear, mainly side wear on the valves stems and guides because the rocker rolles over the top of the valve as it pushes it open instead of dragging over it pushing it sideways. I ran them for a while and they were a big improvement, not just on power but it felt alot smoother too.
Posted 30 March 2004 - 07:41 PM
Rich you didn't cover the wear on the cam lobes... that may increase, I myself have no proof to show whether it does or not.
One thing you have to remember: ANY modification that increases power will increase wear. More power = Less engine life.
Posted 30 March 2004 - 08:03 PM
never know this and now im do im gladOne thing you have to remember: ANY modification that increases power will increase wear. More power = Less engine life.
IT MAKES SENCE
Posted 30 March 2004 - 09:39 PM
i've had 1.5:1 roller tip rockers fitted for about 20,000 miles now, in conjunction with a 276 cam, if as was said on the quote from the minifinity thread, they promote lobe wear, you'd be doing your tappets every few miles to compensate, i've just been checking mine every now and then, and just had the usual few thou of adjustment needed.
so i'd have to say, in my experience, they are no different to standard ones
a friend of mine has a 296 scatter cam and full roller rockers, this set up is about five years old, and still going strong in a hill climb mini, so i'll let you draw your own conclusions.
Posted 30 March 2004 - 09:50 PM
They wont make the lobe wear any greater than normal unless you are using heavier or double valve springs and I never had any problems. The spirngs are the main contributing factor to and force put on the cam lobes.
Posted 30 March 2004 - 10:37 PM
both engines mentioned above are running double springs.
Posted 31 March 2004 - 07:50 AM
so basically there are alot of happy people running roller tips who haven't seen any noticable cam wear.
it may be possible with "heavier" valve springs due to the increased pressure, but again there are happy people running this too.
i think its also worth remembering that when modifying/tuning an engine the age and condition of said engine and component parts may determine subsequent wear, and that no two engines are the same.
or am i completely off the plot?
Posted 31 March 2004 - 09:27 AM
Because all roller tip rockers (that I know of) are 1.5:1 rather than 1.25:1 I think this will increase wear on the lobes.
As for the adjusting the tappets, the measurement is made with the valve closed and the cam lobe at it's minimum position. This part of the lobe will hardly wear at all. I guess the only way to check for wear is to measure the lift and compare that to the cam spec.
However, valve guide wear should be considerably reduced. Either way a few thou of wear of the cam isn't going to affect engine performance much. I guess if you wanted optimum BHP it would be a concern but for most of us what's 1 or 2 BHP?
I use roller tip rockers in my hillclimber and have had no problems.
Wil
Wil
Posted 31 March 2004 - 12:43 PM
silly me!....of course you do your tappts with your valves closed!.. :nugget: ....what can isay....it was early,the pope made me write it, it was my evil twin...it was the fenbillies.....
