Chain Drive Diffs
Posted 03 February 2010 - 07:58 PM
Over the next few months I will be having a Fiat 126 bec built.
Its going to have a Rotrex Honda Blackbird lump, looking good for 250-300bhp. (I hope)
My car is 7.5 inches shorter than a mini................
So who here has used the Quaife gear drive box, did it work as Ive heard its not that straightforward to fit in the Mini due to the short wheelbase. (mines even shorter)
This leads to my next issue, if I go chain drive I will be using my Quaife chaindrive atb - What are you getting (distance) between centres from the bike front sprocket to the rear sprocket centre ?
And are any of you suffering (with similar bhp) overheating chain drives/adjustment issues ?
I know Zcars have built a turbo busa Mini for hillclimbing in Bulgaria, but whether this was chain drive I do not know.
Any other solutions kicking about ?
Posted 04 February 2010 - 04:22 PM
Posted 04 February 2010 - 04:28 PM
René
Posted 04 February 2010 - 04:57 PM
Posted 04 February 2010 - 07:07 PM
I don't if the mods done the trick but it must of helped
David
Posted 04 February 2010 - 07:08 PM
David
Posted 04 February 2010 - 07:13 PM
David
Posted 04 February 2010 - 07:19 PM
David
Edited by R1mini, 04 February 2010 - 07:22 PM.
Posted 04 February 2010 - 09:08 PM
they need more maintainance than a gear drive and you should pay attention to tighten them correctly and ensure the sprockets are aligned perfectly
otherwise you will be pulling down just one side of the chaijn which halves its strength
a scott oiler is a brilliant thing which extends chain life enormously
a good chain cover enclosing it entirely would take a bit of making but would make the chain last forever if it was oil tight enough to keep the chain running in oil
we have just fitted a mini kit into a fiat 600 and it fits an absolute treat
its a v tec but the frame is pure stock mini kit with very minor mods where it bolts to the floorpan
chris
Posted 04 February 2010 - 09:40 PM
Chris - Did your turbo busa Mini run ok with the chain drive ?, ps love the fiat 600 need to see some more pictures ?
Ive read somewhere the Quaife geardrive box is not too easy to fit into the Mini wheelbase.
The enclosed chain box with oiler is an option but I would prefer to drive the car than spend every trip out farting on adjusting the chain.
Replies appreciated folks thank you
Posted 04 February 2010 - 09:53 PM
Thanks for the replies guys.....
Ive read somewhere the Quaife geardrive box is not too easy to fit into the Mini wheelbase - anyone ?
Posted 04 February 2010 - 11:06 PM
One thing I have done on my mini is to move the rear wheel back to increase the wheelbase looking at the fiat you could easily move the rear arch back 4 or 5 inches, done properly you wouldn't notice it
David
Posted 05 February 2010 - 06:47 AM
David
Thanks David, I did think of that as an option but considered all the cutting & shutting would be a chew on. I have seen Minis widened across the track & wheelbase so maybe I need to look at what we are doing again.
It will all fit in the 126 wheelbase Ive seen one !
Ivan
Posted 05 February 2010 - 12:05 PM
David
Posted 05 February 2010 - 02:58 PM
We have a few ideas for chainless final drives on the go, but nothing as yet to commit here. Still in the planning & measuring stage.
Thanks for the offer of a measure up, by lengthening your wheelbase are you able to throw a few pictures on here how you did that ?
The research continues
