How Much Difference Will Oil Pipe Central Pickup Make?
Posted 03 March 2010 - 11:12 AM
My gearbox is under repair, but the garage didnt fit a OIL PIPE HITECH CENTRAL PICKUP in the gearbox(this is due to mis-communication between garage and my friend who is directly contact the garage), the garage say the gearbox need to take parts out again to fit the central oil pick up pipe.
So, I would like to know how much difference will a central pick up pipe make compare to std one? I dont use the car for race, but do drive it a lot in the twisted B road for the weekend.
Thanks a lot for your options.
Regard
Roxtee.
Posted 03 March 2010 - 11:22 AM
Posted 03 March 2010 - 11:36 AM
However it can if oil starvation on cornering is experienced destroy your engine
Posted 03 March 2010 - 11:38 AM
The box is off already, but the garage told me,"oh yes, i can do that for you, but it need take out all parts again, and will cost another 60 pound" which I think will be too much, and dont know if thats worth it or not.
any advice please.
Rgds
Posted 03 March 2010 - 12:10 PM
Regrind crank £80 +
Gasket set £20
The above is just a few of th eparts that you may need if you destroy your engine
Time etc yes it's worth it
Time to remove speedo housing clean off old gasket (minimal) remove retainer ring remove layshaft and laygear and then remove strainer and pipe .....
Fit new COP pipe and laygear, layshaft and speedo housing....
Edited by mra-minis.co.uk, 03 March 2010 - 12:13 PM.
Posted 03 March 2010 - 12:11 PM
Posted 03 March 2010 - 12:42 PM
The standard set up has served a lot of Minis just fine over the years and it does have a much bigger strainer, which is less likely to get clogged up if you're not regularly rebuilding an engine as often as a competition car's.
Posted 03 March 2010 - 12:44 PM
Hi Everyone,
Regard
Roxtee.
Didn't you know they give 20bhp more and put 15 mph on the top speed.
I reality, do not fit a competition oil pickup on a purely road car. The mesh filter is much reduced and more liable to clogging, they are only for competition with frequent strip downs and oil changes. They are like many of the beloved competition parts on the fitting wish list, such as straight cut gears, limited slip diffs and the like. They are for competition, not bragging rites in the pub and not for general road use.
Posted 03 March 2010 - 01:15 PM
--- Sorry, I don't know about this and don't understand what you mean as well. Which one give 20bhp extra and 15mph on the top speed? the Central pick up or the std one? and why it make such big differance?
Thanks a lot
Rgds
Posted 03 March 2010 - 01:23 PM
Unfortunately, like any "competition" component some people like them and some don't, however if you choose NOT to fit a central oil pick up pipe to your unit then you will get engine damage
If you drive like my grandad then you won't need one and in that respect Ivor is correct........... oh and my Grandad has been dead since 1979
Posted 03 March 2010 - 01:37 PM
Posted 03 March 2010 - 03:25 PM
You can get oil surge in any Mini driven in a spirited fashion when cornering hard to the right and the oil is down towards minimum.The bearings an be damaged in a very short time of oil starvation.
It does take around an hour to fit one as the layshaft has to come out which involves taking the cover plate off the LH end of the box to gain access to the locking plate for the lay-shaft. Personally I would have thought about £40 for labour would be right, but others have different hourly rates and a garage charging the now-common £50 to £60 per hour would make a £60 charge about right.
Posted 03 March 2010 - 05:47 PM
He is being sarcastic
Unless Roxtee's grandad is Tom Christie, I really don't think you need a competition oil pipe to drive on the public road.
Posted 03 March 2010 - 08:28 PM
