looking at mocal coolers, basically i know on most tuned/modded engines that used at high revs alot at long periods they are recommended (esp on trackdays).
is it a good idea to fit one to a mini? specifically one with a thermostatically controlled flow?
oil coolers
neil_g
, Apr 01 2004 02:03 PM
6 replies to this topic
Posted 01 April 2004 - 02:03 PM
Posted 01 April 2004 - 04:08 PM
Personally I dont belive that they are needed. At most if not all track days engines are not used at high revs for long periods.
Siggy
Siggy
Posted 01 April 2004 - 05:17 PM
They look good, but on a road car dont really get needed because the oil doesnt get hot enuf to need cooling.
Posted 01 April 2004 - 07:43 PM
i,ve got to agree with siggy and bluemini on this one, for practicality and what it does it's not worth it, unless you are racing your car from dawn until dusk that is!
but if you do don't go for the thermostatically controlled one, otherwise it will prob just be sitting there doing nothing!
Posted 01 April 2004 - 08:15 PM
cheers guys, helpful as ever
Posted 02 April 2004 - 07:10 AM
If you do fit one you MUST fit one with a stat, if not the oil will run way too cool, which is probably worse than too hot.
I ran one (for a very short time) on my old Group N Favroit and that never got warm except once on a 27 mile stage in Kildier (sp?) forest
Siggy
Siggy
Posted 02 April 2004 - 07:45 AM
aye, dont want the engine running cold permenantly..
