Can somebody explain to me what connectors at the back of a 1275GT tacho are supposed to be connected to what?
My mini for some reason doesn't have the correct wires coming out of the loom for the tacho, so I'm gonna have to run em myself, but I don't know where to put them.
Basically there's two bullet connectors on the back of the tacho, one of them I have a wire going to it (the wire has a female connector on it, and IIRC white w/ black). I do not have a wire for the other connector and will need to run the wire myself!
Need help with wiring!
Pavel
, Apr 01 2004 07:51 PM
4 replies to this topic
Posted 01 April 2004 - 07:51 PM
Posted 01 April 2004 - 10:05 PM
One wire is for a power suply, the other goes to the '+' terminal on the coil, which goes were I cant say, had a look at mine but its not the original wiring
Posted 02 April 2004 - 05:05 AM
There should be two bullet connectors coming from the loom, one female one male. Can you check where the male one goes to?
Posted 02 April 2004 - 07:16 AM
One should be a Lucar conector (flat blade) and that is an Earth
Only the later cars had this wire fitted as standard.
Siggy
Siggy
Posted 02 April 2004 - 08:55 AM
I think ive figured it out but according to my 1275GT, the tach is connected to both the positive and negative sides of the coil! is this correct? it also has a brown spade earth going to it from the main instrument cluster
