hi me again, i have some new supspension cones and the haynes says to do it a ceartan way and i have tried this way the front were fine and very easy, but the rear ones are being b*****ds and wont come out, i think the radius arm isnt dropping down properly to relve the pressure is there any magic way of removing theses things bearing in mind the new ones will be even harder to put back, thanks, Dan
suspension
mini-mad-dan
, Nov 04 2005 02:46 PM
8 replies to this topic
Posted 04 November 2005 - 02:46 PM
Posted 04 November 2005 - 02:48 PM
have you removed the shocks? if you have you should be able to push the radius arms down and the cones should just fal out
Posted 04 November 2005 - 02:51 PM
i tried that but they seem to be completly stuck, either that or i am an idiot and missed a nut somewhere
Posted 04 November 2005 - 02:52 PM
Should be four nuts on a mini with internal hinges.
Posted 04 November 2005 - 03:22 PM
nope i got the nut holding the rear shocks of on both ends but it wont budge and it also won't just slide of the bottom bolt...........help me
Posted 04 November 2005 - 03:29 PM
There's two nuts on the top of the shock which you will have to remove. You'll be lucky to get it off the bottom mount with it still being conntected at the top...
Posted 04 November 2005 - 03:35 PM
they are a big pain in the ass, remove the shock complete and then drop the radius arm completey down then get a big hammer and hit the cone and strut then it shud be all lose, it still wont come out but will be loose. then get a 2 small crobar's and try and compress the cone whilst pulling to pop it out. very simple but big pain.
Posted 04 November 2005 - 04:22 PM
i have 2 15" screwdrivers i didnt know there were two nuts to the top half though! thats why it was stuck! this will all be tried on sunday, weather permitting, as if it wont rain now that i may have the answer many thanks, dan
Posted 07 November 2005 - 07:26 PM
yay, i replaced the rear cones, and the shocks for good measure! your help and comments gave me the motivation to try again, turs out the radius arms wouldn't drop because the hand brake was on! and the shocks needed a goog hard whack from a mallet (they were fused to the turrets)
Many thanks, Dan
Many thanks, Dan
