Clutch Siezure
m3ntalist
, Nov 05 2005 12:35 PM
11 replies to this topic
Posted 05 November 2005 - 12:35 PM
Right my clutch has been a bit rubbish since the err racetracks I went around this year. I havent driven for about 3 weeks and now the clutch has siezed up. I cannot press the pedal down. What parts do I need to give it an overhaul. I would like to maybe uprate the clutch so it is a bit sturdier but still not a pain to drive on the road you know..
What sort of parts do you recommend?
How easy is this to do?
anything should look out for?
You know the drill!
Thanks for any help people
Car is 96 SPi
You know the drill!
Car is 96 SPi
Posted 05 November 2005 - 01:12 PM
could be your master and slave cylinder, they would need to be replaced slave is only cheap £20 not sure about the master cylinder
Posted 05 November 2005 - 02:11 PM
master's are not cheap, but fortunately it is normally the slave which seizes...
As for upgrading... firstly, if it's a verto clutch then there's absolutely nothing you can do, other than putting in a turbo clutch which is about as much use as a chocolate teapot... so you need to convert to a Diaphragm Clutch...and that's a whole different story...
On a diaphragm clutch there are different types of spring weightings... Blue ( std road ), Orange ( road/track), Grey ( race ) and double grey ( serious race )... couple that with the different plates you can have, ranging from std, through to bonded, and finally sintered paddles.
Your general combination for your fast road, trackday car would be an Orange diaphragm, and a bonded clutch plate. That combination will cost you 70 -80 groats.
Posted 05 November 2005 - 04:20 PM
May be unlikely, but could the clutch arm be seized?
Posted 05 November 2005 - 05:07 PM
Think its the actual clutch has messed up to me, theres movement up to the clutch
I have ordered a new clutch assembly, will do it next week... ehh!
Ahh well it was worth it
Posted 05 November 2005 - 05:32 PM
My clutch seized once...i didn't know what to do! :sad:
But it had fixed itself by the next morning! :grin:
It was a miracle!
It was a miracle!
Posted 05 November 2005 - 05:33 PM
the clutch fairies must have sorted it for you!
Posted 05 November 2005 - 06:03 PM
i have a paddle cutch :tongue: have no idea what the difference is though
Posted 06 November 2005 - 03:55 PM
It was on its way out anyway......
Posted 06 November 2005 - 05:26 PM
the clutch pluger locks up on later cars for some reason called cack, spray area with plus gas or simular, and normally they work fine
dave
dave
Posted 06 November 2005 - 05:38 PM
I sprayed a LOT. Nothing.......the clutch pluger locks up on later cars for some reason called cack, spray area with plus gas or simular, and normally they work fine
dave
Also warmed engine up and tried during the day etc.
The clutch was knackered after nurburgring and castle combe finished it off!
Posted 06 November 2005 - 06:57 PM
sometimes u need to hit the plunger with an adjusting tool
