I have had to remove the cyclinder head because of a blown head gasket.
Should I replace the head bolts and nuts. Why should this be done, is it really necesarry.
It is a 1275 standard engine with a stage 1 kit, are the standard bolt set up to the job.
Cheers Ben.
Cylinder Head Bolts
bg158a
, Nov 07 2005 10:16 AM
2 replies to this topic
Posted 07 November 2005 - 10:16 AM
Posted 07 November 2005 - 10:38 AM
no you dont need to renew the cylinder head studs or nuts, on some cars you do because they use torque bolts, which can only be used once because of the design of then, just another way to get us to spend more money on our cars if you ask mee
Posted 07 November 2005 - 01:21 PM
Factory bolts on a more or less stock engine can be re-used several times without issue. If you were building a really powerful engine you'd probably want to replace and upgrade the stock fasteners as insurance.
