I want to buy some heat resistant paint, and it has the heat rating on it, but I don't know what temperature the following reach:
- Calipers
- Drums
- Exhaust manifold
- Engine block
Temperatures
Pavel
, Apr 03 2004 09:33 AM
2 replies to this topic
Posted 03 April 2004 - 09:33 AM
Posted 03 April 2004 - 08:53 PM
I use cellulose for all my hi temp stuff, its about £8 a litre and you can get it mixed in any coluor you like. Failing that, go to your local motor factors and pick up a tin of engne paint, but be warned - its horrid stuff to use, realy strings and gooy. Best thing to do is warm it in some hot water first.
Posted 03 April 2004 - 09:39 PM
i wouldn't recommend painting your exhaust manifold, as anything other than the really expensive stove enamaelling will burn off after a while, and then your manifold will look worse than if you hadn't painted it at all!
