Hello Guys & Gals of TMF,
More New Products from Optimise Automotive... both released due to popular demand.
Click the image above to be re-directed to the Optimise Automotive website.
This week we are releasing two new Speaker Pod related products - Speaker Spacers on Tuesday 30th March and Dash Rail Speaker Pods on Thursday 1st April - both launched with an introductory 20% off special offer which will be valid until Sunday 4th April at 23.59.
Please Note To be eligible for these Special Offers it is required that you are registered with Optimise Automotive and subscribed to our 'New Products Newsletter' before the product is released. As you will receive a coupon code, along with instructions on how to use it, in an Optimise Automotive newsletter that is only received by registered Optimise Automotive users.
Andy @ Optimise Automotive
Optimise Automotive New Products
Posted 29 March 2010 - 01:14 PM
Posted 29 March 2010 - 01:23 PM
The first of 2 new products (1 of 2):
Speaker Spacers
A product developed due to popular demand and designed to enable the installation of 6.5" or 6"x9" speakers on the Mini parcel shelf, within the standard 13.5cm factory cut holes. The spaces work by raising your speakers off the parcel shelf, which allows the speaker cone to sit within the standard factory cut holes - simply select the desired depth whilst choosing your trim (1.8cm or 3.6cm).
Only standard MK5 (onwards) Mini's have factory cut 13.5cm holes on the parcel shelf, older Mini’s (Mk1 to Mk4 – prior Mk5/1990) do not have these 13.5cm factory cut speaker holes on the rear shelf.
Please Note We cannot guarantee that our Speaker Spaces range will raise all makes and models of 6.5" and 6"x9" speakers enough to fit within the standard holes. As a result, please check to make sure that your speaker cones fit into the holes on your parcel shelf, within a maximum mounting depth of at 3.6cm (see the diagram below for help).
The maximum mounting depth of 3.6cm is measured from the to surface of the parcel shelf to the underneath of the mounting gasket (the thing you screw through to attach the speaker).
The spacers are secured to the desired location using the M4 bolts & lock nuts provided. Please see "Installation Information" below for details.
from £9.99 (Pair)
Edited by roberts, 30 March 2010 - 02:55 PM.
Posted 29 March 2010 - 01:27 PM
Have you got pictures of the rail pods.....?
What iv been searching for latley is there a way to fit small speakers to the upper dash, by the pillers?
I'll keep looking
Ipod
Posted 29 March 2010 - 01:31 PM
Hi mate
I'll keep looking
Ipod
Yes we certainly do have photos of the Dash Rail Speakers - but we won't be releasing them until Wednesday try not to get too excited though...
As for top dash rail pods - I assume you mean for tweeters? it's something we have looked at but it's not really possible unless you use fibreglass - which we don't currently have the facilities for.
Posted 29 March 2010 - 01:35 PM
Hi mate
I'll keep looking
Ipod
Posted 30 March 2010 - 12:09 AM
Posted 30 March 2010 - 09:06 AM
Think you'll do well with those spacers mate, I had that idea ages ago with the subs I put on my back shelf
The reason we have bought them out is because people want them
Sold numerous sets over the past 6 months or so, so thought it was about time we made them a product.
Posted 31 March 2010 - 01:26 PM
The secnd of 2 new products (2 of 2):
A product developed due to popular demand and designed to enable the installation of our Speaker Pod range to the dash rails. Our cleaver installation system uses the existing pre-drilled holes on the bottom dash rail, which means no drilling into the bodywork is required.
Please NoteIf your internal bonnet release is located under the bottom dash rail you may have to move it to allow for the installation of Dash Rail Speaker Pods.
The pods are secured to the dash rails using the ‘L’ brackets that are included with the kit. Simply attach the brackets to the pods, with the gold screws provided and use the M4 bolts & lock nuts (also provided) to attach them to the bottom dash rail - using the existing pre-drilled holes. Please see "Installation Information" below for details. This is a very fiddly job - which you will need patients for.
from £24.99 (Pair)
Edited by roberts, 01 April 2010 - 03:27 PM.
Posted 01 April 2010 - 03:27 PM
