What is this and what does it do?
Jimbo Limbo (Trials Chimp)
, Nov 07 2005 05:22 PM
11 replies to this topic
Posted 07 November 2005 - 05:22 PM
Hi,
Im doing a flip front conversion and the round thing in the picture below was mounted on the front panel. What does it do and do i need to put it back on?
Also do the tear drop mounts need to go back on, if so do i mount them between the brace bars and the sub-frame?
Posted 07 November 2005 - 05:23 PM
no pic :erm:
Posted 07 November 2005 - 05:26 PM
Posted 07 November 2005 - 05:33 PM
yes you do need the tear drop mounts they are what connect the front of the subframe to the valance.
and the other pic look suspicouslly :cheese: like the horn :fear: :smartass:
:wales:
:wales:
Posted 07 November 2005 - 06:13 PM
I didn't think you used the teardrop mounts on a flipfront?! Especially not between the subframe and brace bars. You have to solid mount the tower mounts and floor mounts.
Posted 07 November 2005 - 06:34 PM
Yes the brace bars should be fixed directly to the subframe with no mounts.
Oh yes, and the other thing is indeed a horn and you will need it!
Edited by Dan, 07 November 2005 - 06:35 PM.
Posted 07 November 2005 - 06:40 PM
I guess there are a few other things that need mounting differently when doing a flip front too??? Do you need to extend any of the wiring for the lights etc to allow for the movement?Oh yes, and the other thing is indeed a horn and you will need it!
Posted 07 November 2005 - 06:46 PM
Most of it can be re-located without much trouble, like you may end up with a starter solenoid stuck to a brace bar if you use an old intertia starter.
Posted 07 November 2005 - 06:49 PM
ok, I C :wink:
It's something I've always wanted to do, but never had the bottle!
Posted 07 November 2005 - 07:07 PM
I've heard the use of a caravan type socket to wire the headlights, but haven't looked more into this?
Posted 07 November 2005 - 07:15 PM
I was thinking that, I would use one of the aircraft multi-plugs we have at work for it I guess (they fit in my pocket soooo easy)!
Posted 07 November 2005 - 07:38 PM
Cheers for the replies, I though my horn would be more erm horn shaped then that lol.
