I'm in the middle of changing my water pump (I thought it was this that was causing a metalic clingking sound) but when I went to take the altenator off I noticed that the bolt that bolts to the positioning bracket and the alternator was missing, as a result the only thing that was keeping the fan belt tight was the two top altenator bolts. I've inspected my alternator and the pulley that the fan belt sits on can move a cm or so in and out of the alternator, now I've checked both my other alternators and they don't do this so I guess mine is fubar'd, yes?!
If so, can I use either of the other two alternators I have in my garage?! They aren't the same model however?
Alternator
Jammy
, Nov 07 2005 08:37 PM
3 replies to this topic
Posted 07 November 2005 - 08:37 PM
Posted 07 November 2005 - 09:08 PM
ist the whole shaft is it just the pully moving
and do they have the same connections, are the same duty. Exchange recon around 25 notes outright new arround 60 notes
Posted 07 November 2005 - 09:21 PM
I'll have a look at connections, it appears to be the whole shaft that is moving?
Posted 07 November 2005 - 09:40 PM
Its bllxd then :nugget:I'll have a look at connections, it appears to be the whole shaft that is moving?
