Mini 998 Engine
24 replies to this topic
#1 adam_mini
adam_mini
  • 394 posts
Posted 05 April 2010 - 03:41 PM
Hi, i was given what i think is a 998cc engine from a 1972 mini?
Engine number is:99h353e-h28618
I have been told it had a rebuild bottom end when fitted to the car and had a stage 3 head fitted but the previous owner removed this and put a standard head on. The engine hasn't done many miles as it was removed from his car shortly after a full restoration because someone pulled out infront of him resulting in him writing off his mini. It has a crack in the selector housing but i know this is replaceable. It will probably need a rebuild before going in a car as i can't be sure of the condition.
I'm just not sure what its worth.
Piccy:
Attached File  DSC02983.JPG   420.58K   22 downloads
Any ideas
Cheers :(
Edited by adam_mini, 05 April 2010 - 03:42 PM.
#2 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 05 April 2010 - 03:56 PM
I've been given two in good order for free recently.... :(
#3 adam_mini
adam_mini
  • 394 posts
Posted 23 April 2010 - 04:13 PM
Anyone else have any ideas what its worth?
#4 lindy119@school
lindy119@school
  • 150 posts
Posted 23 April 2010 - 04:56 PM
standard 998....probably a tenner, but no-ones gonna want to pay for postage.
#5 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 23 April 2010 - 05:22 PM
Let me know if you think of a price mate, might have it off you.
#6 Senile Old Git
Senile Old Git
  • 2,409 posts
  • Local Club: Rutland Minis
Posted 23 April 2010 - 06:09 PM
Engines need to be running to make decent money, the one you have there is a "risk purchase" anything over £25 is a bonus
#7 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 23 April 2010 - 07:42 PM
Early pre '76 that looks like, has a remote gearbox ;) Probably early 70s.
Edited by GreaseMonkey, 23 April 2010 - 07:42 PM.
#8 adam_mini
adam_mini
  • 394 posts
Posted 23 April 2010 - 08:38 PM
How much do you think it could be worth in the current condition and how much if i were to rebuild it?
(Does the remote make it worth more?)
#9 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,129 posts
  • Name: Sean
Posted 23 April 2010 - 08:39 PM
Rebuild costs will probably out-weigh its value.
I'd have guessed at £50-£75 for it.
#10 adam_mini
adam_mini
  • 394 posts
Posted 23 April 2010 - 08:40 PM
In the current condition?
#11 daemonchild
daemonchild
  • 2,341 posts
Posted 23 April 2010 - 08:41 PM
My 73 has a rod change... but prior to that def. going to be remote!
#12 Shifty
Shifty
  • 13,129 posts
  • Name: Sean
Posted 23 April 2010 - 08:43 PM
In current condition, yes.
Its a bit of a niche engine but I'm sure you'd find a buyer looking for a period motor. I'd have given similar money for a unit to rebuild when I did the lump in my Elf.
#13 adam_mini
adam_mini
  • 394 posts
Posted 23 April 2010 - 08:45 PM
One problem is with it the gearbox selector housing has a crack at the gear lever side over one of the holes around 2 inches long
#14 adam_mini
adam_mini
  • 394 posts
Posted 23 April 2010 - 08:47 PM
I might stick it on eBay and see what it fetches, anythings better than nothing i suppose.
(Another thing, are the blocks all the same i.e. would this block fit onto say a 1990 ish cars gearbox?)
#15 Shifty
Shifty
  • 13,129 posts
  • Name: Sean
Posted 23 April 2010 - 08:51 PM
Yes you can ,mix and match early and late stuff (A - A+). You need to use the transfer gears from the gearbox to mate them though.
How bads the crack?
