I have got a set of 1 1/4" twin SU's and am not entirly sure how to fit them, can any body help?
Thanks.
Fitting twin su's.
Bam
, Nov 11 2005 09:41 AM
8 replies to this topic
Posted 11 November 2005 - 09:41 AM
Posted 11 November 2005 - 10:30 AM
Remove old carb and inlet manifold (not so easy if you have the original cast manifold, as exhaust and inlet are attached);
Put on new carb and manifold;
Connect up throttle, choke and fuel;
Get fuelling set-up.
Wil
Wil
Posted 11 November 2005 - 10:52 AM
The only part that I am not so sure on it connecting up the fule lines and the vacume pipe that comes off the distrobuter.
Posted 11 November 2005 - 11:23 AM
Bam i am in the same boat as you.
Iam not sure which cable connects where?
Has anyone got any pics of there in the car?
Sorry to thread jack bam
Posted 11 November 2005 - 06:39 PM
if you have had electronic ignition fitted you won't need the vacuum pipe, must a note because they connected it on mine after the ignition was fitted and when it was tuned by a different specialist they removed it.
Posted 11 November 2005 - 06:51 PM
I'm sorry but that's not remotely true. The electronic ignition simply replaces the points and condenser most of the time. The guts of the distributor including the vacuum advance are still required to map the spark timing in most types of electronic ignition systems.
If you have had an ECU system fitted which includes a throttle position sensor for load calculation that's a different matter but straight electronic ignition still needs the distributor to rotate the baseplate in order to move the sensor around the spindle and therefore advance or retard the ignition.
Posted 12 November 2005 - 10:24 AM
Miniboo, if you email me a piccie of the carbs and your questions about what goes where, I will scribble some arrows on the pictures and tell you what I can mate. :wink:Bam i am in the same boat as you.
Posted 12 November 2005 - 10:28 AM
Cheers MMM.
Will do
Will do
Posted 12 November 2005 - 01:34 PM
hijacking this thread, sorry, Dan should i reconnect the vaccum advance pipe then? it was cut off by a guy at northern mini's when on the rolling road, who took it from 61bhp to 68bhp @ wheels. What difference will having this disconnected make?
