Ok my first problem with my new mini, The wiper motor wheels seem to turn in the wiper arms, this means they get stuck or fall below the windscreen. Do i need to replace both wiper wheels and arms? or is there an easier/cheaper way to fix this.
Also let me know if there is any quick fix you know just in case it rains later.
Wiper problems
Don't Panic
, Nov 11 2005 06:34 PM
6 replies to this topic
Posted 11 November 2005 - 06:34 PM
Posted 11 November 2005 - 07:01 PM
ok one more thing, this maybe a silly question but when i had a look at my battery (I'll admit it took me 5 minutes before i looked in the boot) the negative terminal is connected only to the chassy, is this normal?
Posted 11 November 2005 - 07:12 PM
yeah that is normal
Posted 11 November 2005 - 07:17 PM
cheers mate
Posted 11 November 2005 - 07:23 PM
mine did this and fixed it with superglue, worked so far for the last 6 months
or
u might have to get new arms
Posted 11 November 2005 - 09:31 PM
take the arms off - if the raised ridges are missing from the inside then replace them - if the raised ridges are missing from the mechanism in teh scuttle you'll have to replace that! it's not too hard a job though!
Posted 11 November 2005 - 10:55 PM
pretty much missing from both so i'll try the superglue idea first. thanx again
