Hi all,
I am now the proud owner of 1994 1.3i mini.
When I change gears there seems to be a lot of slack in the takeup and a loud thunk. If I ride the clutch it seems to be ok.
Being new to Mini's, what should I look at. Is it likely to be a worn engine or gearbox mount or something more sinister.
Is this a common or known issue.
Thanks,
David
Clunk when changing gears
Fat Boy Dave
, Nov 11 2005 10:35 PM
6 replies to this topic
Posted 11 November 2005 - 10:35 PM
Posted 11 November 2005 - 10:37 PM
guess works is your man he will help
try a pm to him :cheese:
and welcome to tmf :grin:
Posted 12 November 2005 - 12:06 AM
I'd go for engine steady to start with, then look at the mounts.. .for there the be any slack in the box you would know about it and if it is then could be wear in the diff planet gears amd output shafts... but mounts first
Posted 13 November 2005 - 01:31 AM
Thanks,
I think I'll try the steady. I don't imagine it will be gearbox related as has only done 80,000km's.
Posted 13 November 2005 - 09:27 AM
or 50K miles which is no short distance for a mini gearbox... average is about 70k (110k km) for a box out of a well maintained regularily serviced engine...
Posted 13 November 2005 - 12:31 PM
Sorry to butt in...so an 87k gearbox with no previous attention is likely to need a rebuild to get it all tight again?
I printed off your rebuild price sheet - looks good fella
Posted 13 November 2005 - 03:04 PM
Not always the case, but more probably than not, the telltale of wear in an a box is the condition of the 2nd synchro baulk ring ( chrunches when changing 3rd to 2nd ), if the box is already out wobble the end of the drive shafts, if there is an appreciable amount of moevement this will show that the mica thrust washers on the end of the output shafts are worn out which again will indicate that the diff pin is worn...
