Metro Subby
19 replies to this topic
#1 The Freeb
The Freeb
  • 13 posts
Posted 21 April 2010 - 04:50 PM
im considering putting a 1.8vvc in a my mini do i need to make a custom subframe or can i use a metro subby and just bolt it straight in or will a metro subby still need changing?
whats the best/easyest route to go down?
any help would be greatfull
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 April 2010 - 05:03 PM
so your loosing
* suspension = 2 points
* axles = 2 points
* transmission = 2 points
* steering assembly = 2 points
* engine = 1 point
and you keep 5 points for the body if you don't have to modify it to fit the subframe
looks like a Q plate and an IVA test is needed for your conversion :thumbsup:
#3 Scallywag630
Scallywag630
  • 2,850 posts
Posted 21 April 2010 - 05:55 PM
so your loosing
* axles = 2 points
* engine = 1 point
Totally correct, you little ray of sunshine.....lol
#4 The Freeb
The Freeb
  • 13 posts
Posted 21 April 2010 - 09:09 PM
so your loosing
* axles = 2 points
* engine = 1 point
thanks for the reply but im sorry im new to all this i dont get this point scoring system your using could you explain please.
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 April 2010 - 09:48 PM
clicky
#6 cooper_mark
cooper_mark
  • 110 posts
  • Local Club: 16vminiclub.com
Posted 21 April 2010 - 10:12 PM
your best bet is have a butchers on here
http://www.16vminicl...isplay.php?f=24
also if u want to ask questions then post them here....
http://www.16vminicl...isplay.php?f=11
these guys will help u out...u'll have to register tho...hope this helps
as for the points system....don't always believe what u are always told and as for a Q plate it's *cow poo*
also have a look at this build diary.....he used a mgf subframe cut and narrowed the frame...kept his original REG NO...
http://www.16vminicl...read.php?t=5992
Edited by cooper_mark, 21 April 2010 - 10:20 PM.
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 April 2010 - 10:20 PM
are you saying that the DVLA and VOSA don't tell the truth ?
#8 cooper_mark
cooper_mark
  • 110 posts
Posted 21 April 2010 - 10:23 PM
no just saying this chap.....and other who are doing and have done the same conversion
didn't have to have an IVA or Q plate his mini..
Edited by cooper_mark, 21 April 2010 - 10:39 PM.
#9 samsfern
samsfern
  • 5,243 posts
Posted 21 April 2010 - 10:52 PM
if the modification was done before the rules came in, then it wont need an iva, the vehicle had already been modified before the rules came in, befoe you bought it, wasnt it :) ..... dont worry about it, as long as the conversions done properly itll be fine.
#10 R1mini
R1mini
  • 1,385 posts
Posted 21 April 2010 - 11:16 PM
Bungle,
Are you against all modifications that don't involve an A series? Your like a broken record, leave it out
David
#11 samsfern
samsfern
  • 5,243 posts
Posted 21 April 2010 - 11:26 PM
^^^^^ lol ^^^^^ now to answer the question you originally asked. i wouldnt have thought a 1.8vvc (from an mgf i presume?) would fit a metro subbie without modification, that is if the metro subbie will even fit the mini shell, personally id just "adapt" the mini subframe, that way you can save money by keeping the suspension setup the same (if your not going for coilovers), the brakes the same (hopefully youll uprate them though...) and keep the geometry correct.
#12 Peskett
Peskett
  • 277 posts
  • Local Club: 16v Mini Club forum
Posted 22 April 2010 - 12:14 AM
What was the original Question again? Can't find it in all this off topic cow dung the someone keep leaveing all over this forum about IVA.
Any way as said above get over to 16vminiclub where people will actually help with the actual Questions asked!
I myself have a k series mini as do many others there.
#13 Peskett
Peskett
  • 277 posts
Posted 22 April 2010 - 12:22 AM
the mgf subframe is just a metro subframe mounted into the rear of an mgf, Slightly different bolt on engine mountings.
As for fittment the k series frames are the easier conversion as there's less custom fabrication needed and I think would also be cheaper but you'll need larger wheels and an extended or clubman front end.
#14 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 April 2010 - 06:40 AM
if the modification was done before the rules came in, then it wont need an iva, the vehicle had already been modified before the rules came in, befoe you bought it, wasnt it :( ..... dont worry about it, as long as the conversions done properly itll be fine.
the K series metro wasn't made 27 years ago, you might have a job proving this conversion was done that far back :)
#15 The Freeb
The Freeb
  • 13 posts
Posted 22 April 2010 - 05:30 PM
thanks for all the information i am on the 16v forum but it wont let me post topics or reply to anyones threads. dont no why tho
