URGENT Water problem?!
Posted 12 November 2005 - 09:08 PM
So i filled it up, and allowed everything to cool down before setting off again and keeping an eye on the temp gauge.
Everything went fine for the remaining 100miles of the journey.
Ive got home, and noticed a leak.. what was a steady drip, has now turned into a trickle :S
I presumed it was the radiator, so added some rad weld, which didnt work.. so i looked again.
The water appears to be coming from the side of the engine, next to the radiator?
I HAVE to have the car working for Monday, my job will be gone if i cant make it on Monday (first day of a new job as an Assistant Manager)
Please, any help, or suggestions would be much appreciated... *fingers crossed i can fix it without any parts required, tomorrow*
Hmpphhh.. great way to spend my 18th birthday hey.. fixing my bloody mini! :sad:
Posted 12 November 2005 - 09:11 PM
Posted 12 November 2005 - 09:16 PM
Posted 12 November 2005 - 09:19 PM
It looks like its coming from the actual engine though, not from a pipe... it looks to be coming from the side of the engine, at the point it connects to whatever it connects to.Your bottom rad pipe may have split or may have come loose.
Posted 12 November 2005 - 09:20 PM
Its coming from about half way down, where the pulleys are.Sounds like the waterpump, either the pump itself or its gasket. This is an alloy casting which the fan and its pulley are fitted to and the radiator bottom hose fits to the rear of. If that sounds like the thing then is it leaking from the body or from the gasket face?
Posted 12 November 2005 - 09:29 PM
dave
Posted 12 November 2005 - 09:30 PM
Posted 12 November 2005 - 09:39 PM
Water pump, Either what dan said or its the seals in the pump. There is a hole in the casting of the pump on the dry side of the seals to allow oil to be added to the bearings but will also let water out is the seals are leaking. Also if this is an engine with the small concertina bypass hose it may be that. If this water is coming from the block itself rather than a mechanical joint/seal then its curtens for your block but i very much doubt thats what it is, there has been no freezing recently, or was it that cold in wales.Its coming from about half way down, where the pulleys are.Sounds like the waterpump, either the pump itself or its gasket. This is an alloy casting which the fan and its pulley are fitted to and the radiator bottom hose fits to the rear of. If that sounds like the thing then is it leaking from the body or from the gasket face?
The other question that should be asked is there any Antifreeze in the system. If your coolant looks like tomato soup then you need to change it. the engine will be rusting from the inside out not only that but the water pump is made of aluminium and corrodes at an accelerated rate at high temperatures.
For those that want to know read this
http://www.team.net/...ch/coolant.html
Posted 12 November 2005 - 09:54 PM
Posted 13 November 2005 - 12:32 AM
I think its at the joint, not the actual block.
At the minute it only has water in, i have the bottle of antifreeze ready, but wanted to solve the leak first to avoid pouring it all away!
Posted 13 November 2005 - 01:32 PM
Is there anyway i can stop this temporarily so i can get to work? or am i doomed?
Posted 13 November 2005 - 02:06 PM
Dont suppose anyone in the Manchester area has any of these parts i could buy off them today do they?
Im getting really desperate now!
Posted 13 November 2005 - 04:36 PM
the flexible ones that are made so you can fit without having to remove the water pump are the wosrt "repair" you could ever do!
so get a peice of solid pipe (similar to the heater hose) and a new water pump (which should come with a new gasket), as that will make sure that it's in perfect condition.
and whilst the radiators out, and you've got the cooling system apart, you may as well flush the system to get it working at its peak! :wink:
Posted 13 November 2005 - 06:19 PM
Posted 13 November 2005 - 08:32 PM
It's curious that so many people are saying it's definitely the bypass hose without even finding out if this car has one. Most cars made after 1990 and all cars made after 1992 don't have one.
:cheese:
