Water Pump
Posted 13 November 2005 - 07:15 PM
Jackman
Posted 13 November 2005 - 08:46 PM
Posted 13 November 2005 - 08:48 PM
Posted 13 November 2005 - 08:49 PM
Posted 13 November 2005 - 09:10 PM
Posted 13 November 2005 - 09:14 PM
Film would be good
Posted 13 November 2005 - 09:21 PM
Posted 13 November 2005 - 09:26 PM
Posted 13 November 2005 - 09:31 PM
Best option would be a new one but I don't think there available any more
Edit
They are still available byt are like 40 notes :saywhat:
Edited by Mini Sprocket, 13 November 2005 - 09:34 PM.
Posted 13 November 2005 - 09:42 PM
Posted 13 November 2005 - 10:09 PM
They look flat and straight but the only way to realy tell is fit it to the pump and spin it round and usind a makeshift pointer lined up close to the outer diameter edge and measure how much its out. then mark it at the point you need to strike :nugget: Its a bit like truing up a bicycle wheel.Thats not good, I dont think its the pully, i couldnt see anything wrong with it and it looked flat. Will it do any damage being like it is?
If you leave it like this then it may well cause the bearings in the pump to fail sooner than thier expected life, but funnier things have happened on minis. Excess vibration at higher RPM may result and loosen the bolts, dunno
Straighten it as best you can. They are only pressed steel and do bend quite easily if force is applied in the right place. It may well be distorted in all three axis and a straighter replacement may well be the better option, though like me it might take a few attempts to get a decent one second hand and with new ones costing 40 beer vouchers, its a bum situation. Me being the perfectionist I am, will tell you to replace it, but no doubt some one will contradict me in any case.
There is no substitute for new, except when you don't have the purchase tokens
Posted 13 November 2005 - 10:16 PM
WATER PUMP PULLY ( 1000)
Part No.: M171 Price: 19.99
Thats Chrome too.
Posted 13 November 2005 - 10:19 PM
Buy one and if its bent at least you can send it back till you get a straight one
Posted 14 November 2005 - 05:52 PM
