Rear camber problem
1 reply to this topic
#1 KD88
KD88
  • 11 posts
Posted 14 November 2005 - 01:47 AM
The nearside rear wheel has a couple of degrees negative camber which I presume is good but the offside rear has a couple of degrees positive. I gather this is not ajustable so what might be causing this and how do I correct it.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 November 2005 - 08:13 AM
Worn radius arm bearings or bent arm or mounting point.. As standard Minis have somewhere around 2 degrees +ve camber, but this is dependant on manufacturing tolerances.
