oh that can't be good
#16
Posted 15 November 2005 - 12:24 AM
#17
Posted 15 November 2005 - 12:28 AM
Check for air leaks around the carb, adjust mixture and check pipe for any blockages which may have got in during changing.
#18
Posted 15 November 2005 - 08:52 AM
Registering the car as SORN is pathetic mate. It will take you a day at the most to get it sorted! :tongue:
Im not sure how much fuel line you need, Wheather its right from the petrol tank or not.
But get yourself on
www.minispares.com
www.minisport.com
Or any other mini website.
Get yourself a new fuel line. It will be delivered within a day or 2.
Spend a day fitting it properly.
And while your at it. Why not buy yourself a Haynes manual and learn the basics of a car!
<|Ben|>
#19
Posted 15 November 2005 - 10:06 AM
#20
Posted 15 November 2005 - 10:38 AM
#21
Posted 15 November 2005 - 12:00 PM
i'm an idiot for putting the wrong size fuel pipe on
yes i did put the srong size tube on, i'm a berk. got a new problem now though so i'm makeing a new thread.
cheers for all your help
#22
Posted 15 November 2005 - 07:14 PM
#23
Posted 15 November 2005 - 09:38 PM
i fixed the one pipe i put the small fuel line one. took a drive to buy more clips and did two other tubes.
now the car won't start. it did start then when i tryed to reverese it died. then i tryed again. died again. now no start. it turns over nicly but no start.
#24
Posted 15 November 2005 - 10:12 PM
#25
Posted 15 November 2005 - 10:16 PM
the what, er.. please exspanle in a very simple way. as i am an idiot. or can you tell me were it is the haynes bookhave you took the float bowl cover off to see if the carb is getting fuel?
#26
Posted 15 November 2005 - 11:04 PM
Maybe nothing but all of the above could well mean that it's shorting out against the body/exhaust and would cause all of the symptoms you are describing...
#27
Posted 15 November 2005 - 11:35 PM
Posted 16 November 2005 - 12:05 AM
okay i'll do that tommorow. but another question. were dose the other pipe go to. i got two pies on my flot thingy. one from the pump and the other.....buggers off whos knows were.
#29
Posted 16 November 2005 - 10:10 AM
i will definatly have to try that. i'll take my car to college one day and use the life of just jack it up when the wethers a bit nicer. because it bloody freezing today. althought the car started. i used one of those battire things. er...don't know what thier called but you use then to jump start. ran fine. ahtlough it did die once when i took off the handbreak which makes no sence what-so-everThis may seem off the wall, but check your battery cable from the battery to the front of the car, especially the point where it goes past the exhaust at the back of the front subframe...
#30
Posted 16 November 2005 - 03:44 PM
