Hi all,
Since last time I have moved the wires for the fuse box inside after stripping the mid section of the loom. It looks messy but I know what everything is, honest !
Had a nice delivery the other day, switches, lamps, wire all for the dash build. So off I went organising the dash to accept the new switches and lamps. Much time, swearing and rebating later I had this.
Very pleased with myself I popped out to the mini to see it in place. Didn't fit !! My dash rail gap is 10mm narrower one side and also the switches and lamps were too close to the edge anyway for it to slot in, ahhhhhhhhhh !! This resulted in
But at least I know it fits ok now lol. I filled in the holes and rebated areas on the reverse with car body filler ready for the next go !! And this was it
Should have done this in the first place but I still need to put a couple of switches in the wooden area although the pic below hasn't got the switches moved yet.
I made up a new loom with the delivery and a few relays for the new toggles, a days work but quite pleased with it.
Went to see it all in place in the mini and decided to start it as I hadn't had it running for months. I had no fuse box connected so smart alec here just connected the permanent live to switched live so I could power the engine bay. Started pretty much eighth time and joy turned to panic when a few whiffs of smoke came out of the inside.
I forgot that the headlight circuit had a permanent live feed and a sidelight connector shorted to earth on the engine side of things where the lights connect into the loom. Boom, crispy wires, but limited to the sidelights fortunately. I have some marked wires where the wires stuck together but no more burnt ones. These I will heat shrink to protect to be double sure, the red ones I am thinking of replacing lol.
On a positive note, the engine was running nicely with the exhaust connected up and pasted in and the KnN style air filter in place resulting in a nice sound which cheered me up a touch. Red/green wires on order and an hours work ahead but could have been much worse !!
Plodding on anyway,
Graham
