Vw Golf Mk2 Headlights
mini-man-dan
, May 27 2010 07:00 PM
31 replies to this topic
#16
Posted 14 June 2010 - 05:09 PM
Ok, just finished doing it. Ballsed up one side, but the other went well.
I cut the inner chrome ring to allow it to stretch out an extra 1cm. The hole alignments are ever so slightly out, but this doesn't effect it too much.
I cut it in half between the solid fixing hole and the lower headlight retainer clip, so the ring stays in the correct position without the headlight falling about.
Looks good I think!
I'm now looking for another inner ring from a later Wipac bowl to re-do the passenger side!
Dan
Looks good I think!
Dan
#17
Posted 14 June 2010 - 05:15 PM
Wow that looks wicked
#18
Posted 14 June 2010 - 06:28 PM
#19
Posted 14 June 2010 - 07:10 PM
Yeah, i'm so putting those in my mini!!
#20
Posted 14 June 2010 - 07:38 PM
It's a right pain in the backside to get right, and cut all the old brackets off, but when it's done it's definately worth it!
#21
Posted 14 June 2010 - 10:20 PM
looks ace man!!
#22
Posted 14 June 2010 - 10:25 PM
Corrr. Looks awesome Dan!
#23
Posted 15 June 2010 - 08:23 PM
woweeee! Looks great dan
how bright are these? and are the electrics a straight forward fit
you should patent the idea before everyone does it!
#24
Posted 15 June 2010 - 09:20 PM
Do those have the side light bulb in? Just wondering what they would look like it in a clubby.
#25
Posted 15 June 2010 - 09:34 PM
Yep, they've got a sidelight hole in. Could just put a sticker over this hole that was black, would blend in with the smoked black lens.
And the bulbs are the standard bulbs I believe (and hope!), haven't loked at detail at the sidelights.
Dan
Dan
#26
Posted 18 June 2010 - 11:05 AM
Here's pictures as promised of where I cut the inner headlamp ring to make these lamps 'fit':
Between the fixed point and the 1st headlamp clip.
The outer ring has to have some of the lip trimmed off too, as it doesn't clear the part of the inner ring where the 1st clip goes (due to the inner ring now being 'larger')
Dan
Dan
#27
Posted 23 June 2010 - 08:29 PM
guess whats just arrived cheers for the tips Dan, what bulbs do they take and how do you get the sidelamp to mount
cheers
cheers
#28
Posted 24 June 2010 - 08:35 PM
that will fit on clubman headlight aswell??
#29
Posted 13 September 2010 - 10:37 PM
To anyone thinking of doing this, unless you're ready to completely hack everything apart I wouldn't bother
I've had to:
Cut the inner rings,
Grind back the edges of the outer rings
Cut a big hole in the plastic bowls to let the sidelight holders sit through
Cut back the fixed screw holder to make the lights sit back in the bowls further
It's been a bloomin' nightmare! Good luck to anyone else brave enough to do it
I've had to:
#30
Posted 14 September 2010 - 07:36 PM
just got back from a trip to dusseldorf and you will never believe what is parked in one of the duty free shops in the airport. yep a full mini convertible with 13" compomotive rims (on wobble nuts) fitted with cross hair lamps looks well cool in the middle of the shop.
DSCF6975.JPG 1.5MB 82 downloads
DSCF6976.JPG 1.46MB 67 downloads
