right after a few hard laps around knockhill a had to start pumping the clutch a good few times to get the stick to go into gear , and on the 5th race it just wouldnt go into gear , so had to limp bk to the pits, im thinking the seals are away on the clutch cylinder ? a checked the clutch fluid and it was half empty
any ideas guys and girls?
clutch
Steve Rowe
, Nov 21 2005 06:03 PM
7 replies to this topic
Posted 21 November 2005 - 06:03 PM
Posted 21 November 2005 - 06:44 PM
Definitely got a leak from somewhere, if you can't identify where its coming from replace items by cheapness, clutch pipe, slave, then master.
Posted 21 November 2005 - 07:02 PM
check that theres not anyfluid leaking out the end of your slave cylinder,and running down the back of the clutch cover.
Posted 21 November 2005 - 07:37 PM
Are the seals easy enough replaced on the cylinder ?
Posted 21 November 2005 - 08:38 PM
its best 2 buy a new slave cylinder if its leaking,there not expensive and saves you messing about fitting them,and if its the master cylinder,the bore gets worn,so fitting new seals might not stop it from leaking.
Posted 22 November 2005 - 02:09 PM
hehe
The same thing happened to me after castle combe
Posted 22 November 2005 - 05:50 PM
its not funny :grin: dafty :tongue: what did u do to sort yours ? just replace the complete clutch cylinder ?hehe
Posted 26 November 2005 - 02:52 PM
right today i blead the clutch , and i seen that the master cylinder cap was leaking so i had to use the cap of a cola bottle intill i can get another one anyways i can get gears now better than before but still the pedal isnt right and the bite point of the clutch is right at the bottom, im thinking slave cyliner or the clutch needs adjusted ? anyone ?
many thanks :cheese:
