Need More Volume!
#31
Posted 14 July 2010 - 07:07 PM
#32
Posted 16 July 2010 - 04:18 PM
I may upgrade to a higher amp alternator in the near future, but a) is this a particularly difficult job, and b) will i experience any problems with my current 45 amp one, keeping in mind my system will put out 600W?
#33
Posted 17 July 2010 - 07:44 PM
it should be okay for now, you may only find problems with the system not charging properly if its winter and you have your lights on, heater, heated screen on, music on etc.
you are best off upgrading as soon as you can though
#34
Posted 20 July 2010 - 09:57 PM
I've just come back in after wiring everything up, and something is wrong with the amplifier that's connected to the 6x9's. Wattage and Ohm levels are correct, i've daisy-chained the Remote cable from the 400W subwoofer amp to this one, fitted a distribution block to split the Live cable to allow for two amps, split my RCA cable for the two, and attached an earth to the 6x9 amp.
But after starting the car to check if everything was in order, i'm now getting a really strange feedback from the 6x9's, a sort of low pitch whistling which increases in pitch if i push the accelerator.
The 400W amplifier powering my two subs is unaffected and works as it was doing previously.
Is my 6x9 amp just buggered?
#36
Posted 21 July 2010 - 09:05 PM
Engine whine usually indicates a bad earth somewhere. Try putting a noise suppressor between the amp & headunit to see if that helps. LINK
That's funny, while i was in Dublin the other week i visited a Maplin and the shop assistant tried to sell me this when i asked for RCA splitters.
I'll check my wiring again before forking out for an isolator, as i did think a poor earth might have been the case.
#37
Posted 21 July 2010 - 09:23 PM
and my 70amp alt. is no longer big enuff for my system... i need at least 45 extra mps and the standard alt for an 87' is 45 amps so the extra 25 amps just isnt enuff any more!
#38
Posted 21 July 2010 - 10:31 PM
#39
Posted 23 July 2010 - 09:13 PM
Edited by Carlzilla, 23 July 2010 - 09:18 PM.
#40
Posted 23 July 2010 - 09:59 PM
Youll find you may have to fit ground loop isolators anyway, had to fit some to mine, even though every single connection is perfect (i know this because i used to be an electrician ) , cost £2 each and the delivery was very quick, Passion Auto on amazon was where i got them from, i used to get interferance from engine noise. make sure you fit them closest to the amp, and not the head unit
I've opened up the amp and found nothing wrong inside, and the earth is good, but still i get this noise. Why isn't the same happening with my other, more powerful amp?
#41
Posted 24 July 2010 - 09:27 AM
#42
Posted 25 July 2010 - 09:10 AM
#43
Posted 25 July 2010 - 09:36 AM
#45
Posted 25 July 2010 - 10:19 PM
hmm, could be the splitter being a sod or the wiring after it, you got a picture of the wiring and how its all set up?
I removed the other amp and ran the system without the splitters, i encountered the same problem. The amp was making these noises prior to me having a second amp anyway, but it's got worse since then.
I might just buy another amp. How much do 200W 2 channels go for?
