Thanks for the info.
I have 3 sets of 10" wheels. mambas, old style dunlop alloys and some Wellers (yummy) the only ones that will fit over the KAD Template are the Wellers(Typical)
I am going to run the 12" cooper wheels and brakes for the first few months! and then decide which kit and wheels I like best.
8.4 to 7.5
minimole
, Nov 22 2005 04:54 PM
24 replies to this topic
#16
Posted 22 November 2005 - 07:48 PM
#17
Posted 24 November 2005 - 12:06 PM
Right, after buying minisport 4pots with vented discs i found that my Mambas would not fit - when I called MiniSport they said that the only wheels that don't fit over their calipers are Mambas and Cooper S Reverse rims!
#18
Posted 24 November 2005 - 12:11 PM
Would they fit over non-vented alloy 4 pots?
#19
Posted 24 November 2005 - 12:34 PM
Aparrently they don't fit over the 4pots at all! (vented or non vented!)
#20
Posted 24 November 2005 - 12:57 PM
How nice of them to let you know AFTER said purchase!
#21
Posted 24 November 2005 - 01:06 PM
to be fair I didn't tell them what wheels i had but I bought the car with 100+ minilite style wheels and they fit on them as long as you use knock-on wheel weights and not the stick on ones!
#22
Posted 24 November 2005 - 02:10 PM
I have a set of Minisport 4 pots, 10" steel go over them perfectly ok, but mine are the non vented 7.5's instead of the 7.9's if that make any difference.
#23
Posted 25 November 2005 - 07:59 PM
I thought about going to Cooper s type disks and 4pots but they will cost more.
I would need to change drive flanges too.
I used to set my brakes on fire regularly on my old 998 checkmate so vented 7.9's are a better choice for a 1275 or indeed the 1340 "S" motor I have tucked away for a rainy day
K
K
#24
Posted 26 November 2005 - 02:10 AM
I've heard bits and bobs about fitting Honda discs onto drum brake backplates - it involves cut-down Honda discs, re-drilled to take the mini stud pattern, and an adaptor plate to bolt the caliper onto
I think it was 90-95 Honda's that had the correct brakes to use, and it's apparantly a fairly popular mod in australia?
anyone got any more info on this setup?
#25
Posted 26 November 2005 - 02:23 AM
well - found a bloke who apparently sells them
http://joltfreak.tripod.com/id1.html
Might be worth a try if anyone can get their hands on a set of calipers+brakes?
