Auto missing 4th gear
Posted 25 November 2005 - 03:54 PM
It's really hard to find duckhams so I bunged in some Castrol GTX 15/40 until I could get to somewhere with good oil. Car started ok and I took it out for a burn,though I did find the steering very heavy and the brakes a bit spongier than I remembered,it was going into gear.
However, the other night I took it out and it wouldn't go into the manual 123 gears until I had put it into D,then it would move in 123. Normally I just drive in D anyway though. But yeah every so often I would have to put it into neutral to be able to get 4 gears in Drive. It goes into Reverse fine every time.
Things to consider:
It's been about 2K since my last oil change (put in Comma 20/50 and topped up with Duckhams and this C**p oil when I started losing some about a month ago) It now has Castrol 15/40 in it.
I was driving a very fast,hilly road about 4 times a week,sometimes hitting 80,which is previously unheard of in my auto!
It's very cold weather. LOL
There's 55k miles on the clock.
Does this spell the end??
Posted 25 November 2005 - 04:32 PM
Posted 25 November 2005 - 04:36 PM
hi does it change gear when you kick downLast week I noticed my autobox wouldnt go into 4th gear. I have put this down to oil as my rocker cover gasket is leaking really badly,even though I did try to fix it. And sure enough, when I checked,my oil was below minimum!
Things to consider:
Posted 25 November 2005 - 05:14 PM
Posted 25 November 2005 - 05:29 PM
if the kick down works and you are intamitantly gettin gears and then other gearsYes,kickdown is working!
you need to check the selector
ok from underneath the front of the mini
you need to check the cable to the gearbox
there is a plate with a bulge on under front on the drivers side.
remove this plate ,look in haynes manual if you dont know .
wher this cable meets the gearbox is very imporant . the correct gap needs to be maintained .
also put the car in neutral and then really swowly move it back and forward till it tries to engage gear ,there should be a little play either way before it selects gear.
Posted 25 November 2005 - 05:57 PM
Posted 26 November 2005 - 11:51 AM
