grille buttons
miniboo
, Nov 26 2005 04:23 PM
13 replies to this topic
Posted 26 November 2005 - 04:23 PM
can anmyone tell me how they work and how you attach them?
does it mean you can have a quick release grille?
cheers
cheers
Posted 26 November 2005 - 04:25 PM
with mine they where just 2 bolts that they screwed on too. making the grill quick release. i took them off because i thought it looked cheap. but you are welcome to have my old one if you want em
Posted 26 November 2005 - 04:26 PM
which bit of the body do they fit onto then?
Posted 26 November 2005 - 04:46 PM
if you take the grille off theres a hole behind thats slightly smaller. theres a bit in the corners that hasnt been cut out, the hole will go there
they fit to the bit of metal eather side of the hole behind the grill
Posted 26 November 2005 - 04:48 PM
minimole how much you want for them?
could swap you for some eyebrows?
Posted 26 November 2005 - 05:52 PM
you can have them for the cost of p + p i will dig them out tommorrow
Posted 26 November 2005 - 05:59 PM
coolio
Posted 26 November 2005 - 06:19 PM
Beware, i had some on my everyday mini when i was 17. i went to undo them one day and they had corroded inside the thread. i ended up taking a set of mole grips to them to get em undone!!! f***ed em right up and promptly stopped using them...
Posted 26 November 2005 - 06:21 PM
Never hd a problem with mine, but then mine don't seen to be a ferrous metal.
Posted 26 November 2005 - 06:28 PM
put grease on the threads before you put the buttons on, then they wont corrode
Posted 26 November 2005 - 06:41 PM
I used two large philips screws, just as quick to remove, and you cant see them either as the head fits in between the slats of the grill... :smartass:
Posted 26 November 2005 - 06:42 PM
thats a really good idea
Posted 26 November 2005 - 10:13 PM
IMHO, the "new" style do look cheap as they press on the slats of the grille using a big rubber washer. The "old" style had a female threaded stem that reached between the slats so the head/knob of the button didn't rest directly on the grille slats.
I lost my original buttons when taking the car out for a test drive... I had left them in that valley behind the bumper and the front panel. I ordered a "new" set from Mini Mania and was very disappointed in what I received. I ended up ordering generic aluminum knobs, chrome plated pipe nipples, and a couple of 5/16-24 bolts. I made my own copies of the original design. I also made some test pieces with smaller heads using table lamp hardware. I never used them... but I carry them in the door pocket of my car just in case I do another bone-head move and drive off carelessly with the buttons resting behind the bumper.
