I'm still not sure what to do about those seams though. should I cut them apart, peel them back and replace the metal or just seam weld them as they are?
Edited by Brams96, 01 August 2010 - 10:25 AM.
Posted 01 August 2010 - 10:03 AM
Posted 01 August 2010 - 10:31 AM
i would say its up to you the subframes not going on a car so you can do what you want to it aslong as its strong .take 2 bits of metal lay one on top of the other and weld along edge when done turn over and see if it looks like rainbow colour if not you need to turn up or go slower as you weld hard to tell you easyer to show you .start with the welder up high then try turning the speed of the wire up or down.I cleaned off the galvanise around the edges before welding. Thanks for the tip, I am still getting used to the welder and mask but it's going ok so far. The welder has only got position 1 & 2 with a min & max switch as well so not much adjustability. I will give what you said a go tonight.
Posted 01 August 2010 - 10:48 AM
Posted 01 August 2010 - 12:17 PM
Posted 01 August 2010 - 12:26 PM
Posted 01 August 2010 - 01:24 PM
Edited by Brams96, 01 August 2010 - 03:01 PM.
Posted 02 August 2010 - 08:14 AM
Yes it's the right way up. I usually spray the heel board and parts of the subframe that won't be accessible when fitted with waxoyl, fit the subframe, then inject it with waxoyl. So yeah you can do it when it's on.
