Rear lights
Posted 26 November 2005 - 09:33 PM
Do they need to have the defused glass or would for example a normal front spot lamp be ok to use as a reverse lamp?
My van being of 1980 vintage I don't need either as they weren't fitted as standard, but trying to reverse in the dark is a nightmare, trying to use the brake lights to see with lol. So what I want to do is fit something that doesn't look like the cr@p that BL bolted on as an after thought. I have something in mind but need to know if it'll be legal...
Posted 26 November 2005 - 09:35 PM
Posted 26 November 2005 - 09:37 PM
Posted 26 November 2005 - 09:40 PM
Posted 26 November 2005 - 10:16 PM
The Road Vehicles Lighting Regulations 1989
But basically, if it's pre 86, you can whack a search light on the back, and aslong as it has a tell tale on the switch or is automatically switched on my the selection of reverse its ok...
Edited by GuessWorks, 26 November 2005 - 10:19 PM.
Posted 26 November 2005 - 10:21 PM
Posted 27 November 2005 - 02:12 AM
Oh, Im after those Jewled rear light covers too.
as for what to use, Im pretty sure ANYthing that is White will be legal as Reverse lights arent required for MOT at all.
<|Ben|>
Posted 27 November 2005 - 08:53 AM
Posted 27 November 2005 - 12:33 PM
And 'anything' is very much not legal. In fact I was under the impression that even those large Lucas boot mounted lamps the Works used were illegal on the road, as in this:
A reversing lamp not bearing an approval mark:
The total wattage of any one reversing lamp shall not exceed 24 watts
Since all cars after '86 must use an approved lamp or equivalent then only cars before '86 may use unmarked lamps and unmarked lamps must not be over 24 watts. The driving lamps that the woks put on the back (like the one on E-bay above) are 55 watt I think since they are actually driving lamps. They're rallying lamps for off road only.
Edited by Dan, 27 November 2005 - 12:34 PM.
Posted 27 November 2005 - 12:55 PM
However, it must either be switched automatically either from the gear lincage or the box or it must have a warning lamp fitted and clearly visable from the drivers seat. This must be closed circuit (ie the warning lamp must illuminate when the reverse lamp is switched on)
It must not exceed 24 watts
It must be said that while these regulations do exist it is rare for them to be upheld. We used to fit spotlamps as reversing lights and I've never been bust for it in 30 yrs of motoring. Also there are very few traffic cops that actually know the law relating to lighting (although many think they do)
A good example.
I run a customised van for my work and it is fitted with al sorts of 'extra' blue accent lighting.
I was recently stopped and a traffic cop tried to tell me that they where illegal.
I asked him to tell me why and he came up with all sorts of excuses.
I said to him "You can ask me to turn them off if you want but if you say they are illegal then give me a ticket and I'll see you in court' -- he made some excuse and dissapeared ------ fast
Posted 27 November 2005 - 02:33 PM
Restrictions on fitting blue warning beacons, special warning lamps and similar devices
16. No vehicle, other than an emergency vehicle, shall be fitted with-
( a ) a blue warning beacon or special warning lamp, or
( b ) a device which resembles a blue warning beacon or a special warning lamp, whether the same is in working order or not.
Edited by GuessWorks, 27 November 2005 - 02:34 PM.
Posted 27 November 2005 - 02:43 PM
The key is in 'b'Blue lights are for emergency vehicles only, so be careful where you tread... Parker, you may find you bluff is called...
There is no way that it could be argued and won in court that underbody neons, washer jets etc could constitute a warning beacon or warning lamp
Posted 27 November 2005 - 02:53 PM
Posted 27 November 2005 - 03:32 PM
Reading through the regs there is only that point and pos. this
No person shall use, or cause or permit to be used, on a road any vehicle on which any lamp, hazard warning signal device or warning beacon of a type specified in an item in column 2 of the Table below is used in a manner specified in that item in column 3.
11 Any other lamp Used so as to cause undue dazzle or discomfort to other persons using the road.
Only real exception would be if I had one fitted to the rear of the vehicle -- I do but that is covered as well because it is disconected in such a way that it complies to the regs and I only re-conect it if I can be bothered at a show
No vehicle shall be fitted with a lamp which is capable of showing any light to the rear, other than a red light, except - blah, blah blah -
