Mpi Radiator Fan Stays On
7 replies to this topic
#1 Looneypete
Looneypete
    Starting My Mini Up
  • 3 posts
Posted 11 August 2010 - 12:52 PM
Hope someone can help. My 1996 MPI cooper radiator fan seems to come on before the engine is up to temperature and then stays on until the engine is switched off. Does anyone have any ideas what could cause this? Also the car seems to be idling less smoothly than usual.....not sure if this is linked?
Very best......Pete.
#2 rocketbeta
rocketbeta
  • 56 posts
Posted 11 August 2010 - 02:00 PM
I had the same problem, the ground wire to the electric fan was grounding itself on lower part of the grill. I just put electric tape on it and it doesn't come on anymore.
#3 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 11 August 2010 - 02:19 PM
Could also be a faulty temp sender unit (usually located in the front bottom corner of the radiator, but check as MPI models may be different) or if you have only recently bought the car check the sender unit wiring, to make sure it hasn't been intentionally bypassed manually by a previous owner. This is quite common to make the fan stay on permanently to help with over heating issues.
#4 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 11 August 2010 - 05:35 PM
Please see Rover attached technical bulletin regarding constant cooling fan. Try a new temperature sender first (Around £15), then buy the loom (£40). Wiring loom is available still from minispares etc.
Ryan
#5 Alpha Tango
Alpha Tango
  • 71 posts
Posted 11 August 2010 - 08:24 PM
Try this one first as I had the very same problem about 3 months ago on my MPI and I seem to have fixed it for free. I disconnect the connector from the
coolant temperature sensor and I gave both the sensor and the connector a generous squirt of WD40, sorted.
#6 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 11 August 2010 - 11:45 PM
i agree with that. It cured the problem for me and that was nearly two years ago. Cheap too.
#7 Looneypete
Looneypete
    Starting My Mini Up
  • 3 posts
Posted 12 August 2010 - 08:57 AM
Thanks for all your ideas and help, I will try these at the weekend at let you know which works!..........hopefully.
Very best,
Pete.
#8 R32Egor
R32Egor
  • 313 posts
Posted 18 August 2010 - 05:26 PM
Hi all,
I had the same problem with my mini that i have just bought. I am glad somebody else had this problem as i thought it was strange but normal :)
Anyway after investigating i found that the Rover mod had been carried out but the wiring connection was "******* poor" and one of the wires was disconnected - so just a quick reconnection and some heat shrink installed and hey presto no more problems :wub:
Hope you got yours fixed
Jay
