My Engagement Ring
#46
Posted 30 September 2011 - 07:46 PM
So if yours works like mine then tyres are good. Looking forward for lots of pics matey !
Graham
#47
Posted 02 November 2011 - 07:08 PM
I know this was against peoples advice and they said I should buy a full heel board, but I'm too tight! I'm tempted not to dress the welds as I don't see any need, (unless anyone has any different advice????) Unless the subframe fouls on it!
You can see where the cutting wasn't very good, and a bit had to be added in
On to the other side!
I bought a compressor off ebay the other day, the worst ebay listing in the world!
I was the only bidder! £50!
Air tools will be coming soon!
#48
Posted 02 November 2011 - 10:08 PM
I semi dress my welds down, knock the tops off for a cleaner look, and as you say they won't be seen there. Nice work and speed up as me and Hugh are racing away lol !!
Graham
#49
Posted 03 November 2011 - 06:57 AM
#50
Posted 03 November 2011 - 10:58 AM
Would you listen to that Graham, he thinks he'll catch me up!! Actually he is doing well - he is more careful than me - just don't tell him that.
Hugh
Edited by hughJ, 03 November 2011 - 10:59 AM.
#51
Posted 03 November 2011 - 12:35 PM
#52
Posted 17 November 2011 - 10:07 PM
I need to make a cardboard template to make a steel piece to fix the floor before I can put the mount in!
#53
Posted 18 November 2011 - 01:06 PM
After an interesting few months (long story) the project is progressing again! 80 quid worth of steel made me a spit! (Thanks to my mates for paying for the metal for my birthday) and thanks to Chris for his skill!
Hi Carlos,
just reading through your thread and it all looks good (apart from your hand vs grinder photo). I'm interested in how you made / fitted your spit as I'm going to have to do the same at some point. From the photo it looks like you've braced this on the top of the rear arches (welded?). Does the pole go through the length of the car or have you got separate ones front and back? What did you mount it on at the front? Any more photos of it etc?
At what point in the project did you put it on the spit? I see you'd already sorted the front end and step / sills. Was this just to get better access to the heal board and floor? I'm just trying to figure out what order to the replace all my panels in at at what point I should put it on the spit.
Thanks for any help
Chris
#54
Posted 18 November 2011 - 01:53 PM
Hi Carlos,
Thanks for any help
Chris
The hand vs grinder pic wasn't mine, someone else put it on the thread!
As for the spit, it has a length of scaffolding pole running through the middle of the car, this is then mounted to the front bulkhead and to the rear it is bolted through the shocker holes, and then to the parcel shelf!
I replaced the floor panels, flitch panels and door steps before it went on the spit, my concern was how strong the shell was before putting it onto the spit.
The spit has given me really good access to make a couple of floor repairs and sort the subframe mounting points
Edited by Carlos W, 18 November 2011 - 02:02 PM.
#55
Posted 18 November 2011 - 07:15 PM
#56
Posted 18 November 2011 - 10:25 PM
#57
Posted 26 November 2011 - 10:10 AM
This is a rust sandwich, there are plates on both the inside and outside!
Tasks for this weekend, repair this and put in the new subframe mount
#58
Posted 26 November 2011 - 07:15 PM
Graham
#59
Posted 26 November 2011 - 07:30 PM
just need to dress the welds
#60
