i think the standard speakers a 5 inch, if in doubt get your tape measure out!
What kit to get?
RustyFuknut
, Dec 05 2005 05:58 PM
84 replies to this topic
#76
Posted 16 December 2005 - 11:58 AM
#77
Posted 16 December 2005 - 12:37 PM
is the measurement just the cone or the whole lengh of it?
Tom
Tom
#78
Posted 16 December 2005 - 01:35 PM
should be the cone to the outer edge of the rubber usually (although most 12" subs are only 11" when measured like this!)
#79
Posted 16 December 2005 - 07:14 PM
ARRRRRRRRRRGH! *cries* a friend of mine said that setup wont work? that the subs and amp arent good and the amp for the subs is too powerful and will kill them? Is he just talking *******?
really worried now =(
Tom
Tom
#80
Posted 16 December 2005 - 08:11 PM
he's talking *******, you can put a 1000watt rms amp on a 50 watt sub and it will only damage it if you give it too much gain.
Underpowering a sub is more likely to damage it, i really wouldn't listen to your mate!
All the amps and speakers i recommend have around the same rms power figure (usually the amp is slightly more).
#81
Posted 16 December 2005 - 08:13 PM
if you are going with the setup you said earlier, you are using RE and JBL stuff which is very good quality (i've been running JBL for 5 years and they've had a thrashing).
#82
Posted 16 December 2005 - 10:08 PM
thanks matey, will continue with the original setup then
do those jbl componant speakers you suggested come with a grill?
Tom
Tom
#83
Posted 17 December 2005 - 10:59 AM
yeah they will come with grilles
#84
Posted 17 December 2005 - 12:20 PM
good stuff, on with the saving and buying and installing then, thanks again for the help much appreciated.
Tom
Tom
#85
Posted 19 December 2005 - 12:21 PM
Tell him he's a homo Too much power will only kill speakers if you abuse them...though you can obviously do that with not enough power or the "right" amount of power!
