1971 Clubman Estate
393 replies to this topic
#16 longtimenomini
longtimenomini
  • 432 posts
Posted 27 October 2010 - 05:47 PM
several attempts...resealing, renewing pipes and clips, changing sender (again), eating sweets and.......
It friggin works .... and no leaks ....... :thumbsup:
HOWEVER....
another attempt at getting cone out.... got the compressor to grip (more thread in)....started to compress
compress
compress
nearly enough....compress
just about there....
BANG!!!!
the cone was so old the thread/ nut in the rubber pulled clean out
I now have half a compressor tool bar sticking out of engine bay (unable to unthread it as there is nothing to hold it at bottom)
hehehe oh well, looks like I will have to bring in the big guns ..... Angle grinder "V" 40 year old cones and doughnuts
:thumbsup: FINISH HIM :)
#17 longtimenomini
longtimenomini
  • 432 posts
Posted 05 December 2010 - 05:53 PM
pants....weather and other bits slowed me down to ...... a stop really!
ok picces below shows the cone with the thread pulled clean out!!!!, no contest for an angle grinder...I WIN
New bottom arms and bushes on
New Hi Lo's fitted on front
new gear knob....much better, now i dont have to change gear with my fingertips
Rear lap belts in....will eventually put in some 3 pointers as I can re-use the 2 mounting points
A few things have cropped up that I need...so looks like I will upgrade brakes sooner rather than later...keep watching
#18 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 05 December 2010 - 08:35 PM
Where have you got those rear lapbelts bolted to on your Mini? My Clubman estate doesn't have rear belts, and i'm curious as to where and how they're mounted.
#19 longtimenomini
longtimenomini
  • 432 posts
Posted 05 December 2010 - 08:47 PM
from ebay(brand new)...just type in lapbelts
mounted on rear crossmember and rear arches with spreader plates ... these were just quickly put in for reference of location and not being used yet and before they are I am having some additional plates welded onto mounting points.
#20 longtimenomini
longtimenomini
  • 432 posts
Posted 27 February 2011 - 11:55 AM
a few new bits collected over time......
#21 bcjames
bcjames
  • 2,728 posts
Posted 27 February 2011 - 12:02 PM
Wow, how have I not seen this thread yet! Awesome clubbystate =]
#22 R.S.P
R.S.P
  • 500 posts
Posted 27 February 2011 - 12:58 PM
Looking good mate will be like a differnet car with all that new braking power =]
#23 longtimenomini
longtimenomini
  • 432 posts
Posted 27 February 2011 - 01:00 PM
SAFER !!!!!!!......things get a bit hairy
#24 longtimenomini
longtimenomini
  • 432 posts
Posted 27 February 2011 - 01:09 PM
rear camber plates (well one of them) and drums on
#25 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 27 February 2011 - 01:39 PM
looking good mate! nice work!
#26 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,415 posts
  • Local Club: urrrr no
Posted 27 February 2011 - 01:57 PM
Missed this thread before, looking great. I love estates!
#27 longtimenomini
longtimenomini
  • 432 posts
Posted 27 February 2011 - 02:29 PM
front bits on....
servo in, but not plumbed in yet......need to tap into manifold as no take off (unlike later hs4 types) =]
#28 MiniJosh92
MiniJosh92
  • 1,577 posts
Posted 27 February 2011 - 04:17 PM
Such a gorgeous estate =]
#29 longtimenomini
longtimenomini
  • 432 posts
Posted 27 February 2011 - 04:55 PM
Such a gorgeous estate :bah:
THANK YOU :thumbsup:
#30 longtimenomini
longtimenomini
  • 432 posts
Posted 05 May 2011 - 05:41 PM
bit of an update....piccies this week i promise
1 - went in for MOT...... a couple of advisories but YAY, another 12 months motoring
2 - fixed leak on rocker cover gasket
3 - changed over from old paper filter to newer housing and screw on oil filter (thanks to green and white for supplying parts) ...oil leak was one of advisories....oh yes and oil and filter change
4- replaced bulb on number plate light and dodgy wiring on front indicators
5 - Still havent found cause on knocking on front going into a bump ...GRRR
6 - Servo all plumbed in .....oooooooh feels like a 'new' car.....that stops
7 - got around to buying and fitting the longer srew/ bolts that 'hold' the drum onto the hub...yes I know the wheel holds them on.....but It was bugging me.
8 - had suspension geometry set up by Green and Whites......sweet handling now......will be even better with new wheels
AND a set of wheels..........but which ones?
answers on a postcard....pictures this week (a midget gem to the winner)
Mini Spares
