1971 Lotus Inspired Clubman Estate
681 replies to this topic
#316 hazpalmer14
hazpalmer14
  • 682 posts
  • Local Club: cumbria mini cruisers
Posted 02 February 2019 - 09:43 AM
Hinges were for boot board .... changed my mind
Brackets .... nope not for boot board
All will be revealed .... probably in next few days
Also Got delivery today from newton commercial , will get some pics up this weekend
Hinges with little gas struts would be good
#317 longtimenomini
longtimenomini
  • 708 posts
Posted 02 February 2019 - 03:27 PM
Couple of jobs started/ done ....
Job 1 not quite finished , as per usual got sidetracked with another job
#318 longtimenomini
longtimenomini
  • 708 posts
Posted 03 February 2019 - 05:48 PM
Ok .... will start with pics
Q AND A later
#319 KTS
KTS
  • 2,289 posts
Posted 03 February 2019 - 06:15 PM
Nicely done !
#320 longtimenomini
longtimenomini
  • 708 posts
Posted 03 February 2019 - 06:46 PM
Nicely done !
Thank you .... pics don’t do the ‘movement of board with pistons ‘ justice
mm to spare .... took a lot of thinking through
#321 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 03 February 2019 - 09:22 PM
New Old Stock part?
Bit of wizardry there with that nifty installation! ?‍♂️
#322 longtimenomini
longtimenomini
  • 708 posts
Posted 03 February 2019 - 09:40 PM
New Old Stock part?
Bit of wizardry there with that nifty installation! ‍♂
None shall pass ! ......... me
#323 longtimenomini
longtimenomini
  • 708 posts
Posted 04 February 2019 - 07:14 PM
After stealth boot install , arming switch needed to be equally subtle ( several head scratching moments for each section of kit), original aircraft switch supplied was bright blue , er... no
After blu tacking to several places in car , have decided on this ... will trim switch so it sits more flush .
#324 KTS
KTS
  • 2,289 posts
Posted 04 February 2019 - 07:33 PM
...thought for a moment you'd gone ultra stealthy and wired it up to the heater fan switch !!
#325 longtimenomini
longtimenomini
  • 708 posts
Posted 04 February 2019 - 07:54 PM
I’d take off like a scolded cat every time it got cold
#326 longtimenomini
longtimenomini
  • 708 posts
Posted 08 February 2019 - 04:11 PM
Rear panels in ... need some tweaking but look nice
Then moved onto job I was avoiding .....
#327 longtimenomini
longtimenomini
  • 708 posts
Posted 08 February 2019 - 06:47 PM
1 step forward , then ...... borrow a car and drive 15 miles in opposite direction !!!!
Sheared exhaust mount ... at start of job ....
Snapped manifold stud in head ... just enough thread to get it out
Already had new set from a previous shopping spree ... new set in
#328 longtimenomini
longtimenomini
  • 708 posts
Posted 09 February 2019 - 07:55 PM
Rest of kit I’ve got to fit in ....
If I don’t get side tracked ....again
Tried bleaching washer bottle .... didn’t work
Will investigate peroxide and daylight ... unless anyone has a suggestion ?
#329 KTS
KTS
  • 2,289 posts
Posted 09 February 2019 - 08:05 PM
Considering how manky they can get it looks like you done pretty well with that
I'm not sure if the plastic itself degrades over time and goes cloudy - have you considered painting it ?
I guess youd have to mask off a strip to show the level
#330 longtimenomini
longtimenomini
  • 708 posts
Posted 09 February 2019 - 08:16 PM
That pic was 1st bleach this is final in bay .... needs to be whiter
Paint maybe only option
