Edited by bradderz, 02 November 2010 - 08:07 AM.
Stuttering When Cold
#16
Posted 02 November 2010 - 08:05 AM
#17
Posted 02 November 2010 - 08:09 AM
#18
Posted 04 November 2010 - 08:21 PM
Cold running (rather than cold starting) problems that disappear when warm to hot can also be attributed to the manifold heater or PTC heater as it sometimes called. Check that the fat brown wire is attached to the spade terminal on the base of the manifold (directly under the manifold if you were looking down at the throttle from the top( the underside of the silver knobly bit at the bottom of the inside of the manifold, under the throttle disc)). It is fairly common for this connection to be burnt, loose, or even disconnected. Also check the relay pack large connector for similar scorching/ burning of the same wire (brown/ blue? from memory) as well as the circuit track on the inside of the relay pack. If this all looks fine, it could be that the heater itself is faulty. The heater should read an ohm value between the spade terminal and the manifold somwhere in the 100's depending on the temperature. If there is infinity ohm resistance with a cold heater, the heater is faulty.
I have this random blue/red wire down the back of the throttle housing not connected to anything.....
is this the spade connector that connects to the ptc heater under the housing ?
#19
Posted 04 November 2010 - 08:39 PM
has anyone seen this happen with spark plugs before, not working when cold and then working when warmed up?
Yes my car used to misfire like crazy when cold, but things improved to drivable when warm. Turned out to be some kind of intermittent problem with spark plug number 4 when cold, so I replaced the rouge spark plug and things improved considerably but were still not perfect. I have since discovered that my car heater matrix was completely clogged up and there was therefore no water flow around the heater pipe circuit. As my heated inlet manifold is also plumbed into the heater circuit the manifold wasn't getting heated either, since flushing and clearing the system (and now with warm water flowing everywhere) the car seems to run a lot better when cold!
#20
Posted 05 November 2010 - 05:13 PM
EDIT
Edited by Sprocket, 05 November 2010 - 05:20 PM.
#21
Posted 16 May 2018 - 06:58 AM
